Have a Distributor Points Question
Putting the 427 together this weekend and getting it ready to mount on the run stand and need to buy the remaining items on the way home today.
I always try to use name brand parts and alway seem to buy Echlin parts when it came to the ignition system. When did a simple set of points become so expensive????? Last set I bought was a few years ago but don't recall paying 20 bucks for a set.
Echlin Distributor Points
CS786 -- $25.49
CS86 -- $25.49
CS7860 -- $21.49
CS89 -- $18.49
CS7860C -- $16.49
CS786P -- $19.99
What are you using? Also, which of the above Echlin numbers do I need?
CS786 -- $25.49
CS86 -- $25.49
CS7860 -- $21.49
CS89 -- $18.49
CS7860C -- $16.49
CS786P -- $19.99
Summit's prices are in same ball park (or higher depending on spring pressure):
http://www.summitracing.com/search/p...ition%20points
I have a couple of CS786 sets in stock, and several sets of Delco point sets (all for my "future usage"). Think Lars recommended the CS786 sets to me (way back when).
Plasticman
Plasticman
CS786, takes me back. I sold auto parts at a NAPA store in the 70's; CS786 points and RR175 condensors across the counter by the 00's for V-8 Chevy's back then.
NAPA Echlin has their catalog online, as well as NAPA Online in general, so you can puzzle out most of these. We never stocked the CS86 standard duty, always just CS786 that was a bit heavier duty (and is still marked so in their catalog).
CS7860 has a heavier spring for high-rpm (above 6K, IIRC).
And yes...$20+ each? Ouch. That part is new! :-0
The CS786 is what's on my list to pick up today @ $25.49.
AC Delco D106P are $28.99 @ O'Rileys Auot Parts. Just WOW.
On EBAY there is a seller with the nickname Black Schnauzer selling Borg Warner points HP 112 (28-32 oz HD points) for $50 for a set of ten. Also on EBay Ive seen Accel 8140 kits consisting of HD points & condenser going for about $15 a set.
Received 6,990 Likes
2015 C2 of Year Finalist
Just last fall I bought a set of standard brand heavy duty points from advance auto for less then 20 bucks my car runs great with them
Manufacturing economics.
About 40-50 years ago, every car on the road used breaker points. The point companies were probably selling maybe 50 million point sets a year. Crank 'em out all day and all night for next to nothing and sell them for $2.95, or less with condenser and new rotor, I don't remember what i used to pay in 1975.
Now, there are a lot less sold per year, plus dollar devaluation means that about $3.50 buys what $1 did in 1975, so do some math and you come up current $ value of about $11 for a point set, if they still made them in bulk, but they are now special parts ,a nd yeah, I can see $25-$30. If you want to feel fortunate, price a set of original Magneto Marrelli points for a 308 car, multiply by four for the two points per dizzy, and count your blessings.
I also remember when new GM water pumps were $12,a nd a new L79 short block (with cam) was a little over $300 out the door at the Chev parts counter. And gas was 31 cents/gal for premium, etc. about the same time
Doug
Doug
Received 1,895 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I had great luck with Accel points. 7500 RPM and 800+ HP in my old 540. They lasted forever and held their setting well. Cheap stuff will move around a lot and bounce early
The old Delco DP-112's were great if you can find them.
Jim
Jim
Points in 1973 3.50 each, gallon of gas was .35.
Points in 2013 25.00 each, gallon of gas is now 3.80 in Calif.
Looks like the Auto Parts suppliers are less greedy than the Oil companies.
What was already mentioned about volume and pricing is exactly correct. A matrix is used to set pricing, how old is the vehicle and how many are used per year. Unfortunately our cars are very old and very rare now so open the wallet.
Received 1,126 Likes
In the 80's I had a Valley Forge route that serviced garages and I used to sell MC-82 points for $1.00 each.
Today in my store I recommend Standard Ignition, Blue Streak DR-2371XP, they sell for under $20.00 each and are rated at a higher RPM.
Joe
http://www.standardbrand.com/Online%...g/Content.aspx
Joe
Instead of hand wringing over the cost of older parts I'm grateful I can still get 'em.
I can walk into NAPA and get brake drums, shoes, shock absorbers, water pumps, fuel pumps, all manner of gaskets, spark plugs, you-name-it, for my 50 year old cars and darn grateful for it.
Compare these prices to equivalent parts on modern cars and you may find driving these classics is a bargain.
I have some old Hot Rod magazines from the 1960's,a nd let me tell you what a bargain headers are today.
Hooker headers for you new 396 '67 Camaro: $400 in 1967. That is about $2000 today. You can buy Hookers for the same car now, for somewhere around $400. But back in 1967, they had to buy the car, cut and fit, cut and fit, make up jigs, etc, etc,and of course, if they were first to market, you had to pay if you wanted 'em.
Doug
Location: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
I tell people everything costs the same today as it did back in the day. You just add a zero.
Doug
Doug
Received 6,547 Likes
C2 of Year Finalist (track prepared) 2019
Lots of wisdom in your words, Frankie.
I, too, am grateful that it's still a simple matter to keep my old rolling stock on the road.
Anecdote: A few years back, I went into NAPA to ask them to order a Voltage regulator for my '63. Then didn't need to order it; they had one on the shelf!
Jim
The caveat to this strategy is that it can take an extended period of time to get your part. So, do this only if you can stand to wait.
Jim
Yes, we are very fortunate in this regard. Plus, it's great to watch the reaction of the counter guy when you ask for "points." "What are points?", he'll usually say.
