110 octane "leaded" gas
Old 07-13-2013, 08:18 PM
SS409
SS409's Avatar
Default 110 octane "leaded" gas
I would like to mix this with the 91 octane 10% ethanol blend here in So Ca. Two gallons mixed with 15 gallons of 91 should net out at around 93.
Is there any reason why I shouldn't mix leaded gas with the ethanol blend? This would be for a 66 327/350hp L79 with 11 to 1 compression. Thanks
Old 07-13-2013, 08:48 PM
Mike Ward
Mike Ward's Avatar
Why? Are you experiencing detonation?
Old 07-13-2013, 09:24 PM
SS409
SS409's Avatar
Yes, the previous owner decided to keep the 11 to 1 compression.
I've been using NOS racing formula octane booster with good results but I don't care for the buildup on my spark plugs, cylinders and valves that the MMT is creating.
I don't think the leaded fuel would be a problem but I'm very familiar with murphy's law.
Old 07-13-2013, 09:53 PM
ghostrider20
ghostrider20's Avatar
The NOS octane booster is worthless in all regards.
Mixing fuels as you plan is fine, will mix as well as pouring two buckets of water together.
I am running the factory compression, maybe a tad more and have good results on 92 octane in all but the hottest of days in the summer.
I have and do spike with 100LL avgas. Mixed 50/50 with 92 octane yields 96 octane. 25/75 will yield 94 octane.
- Mark
Old 07-13-2013, 10:15 PM
DZAUTO
DZAUTO's Avatar
Received 3,772 Likes on 1,674 Posts
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
There is a race gas distributor in Okla City. I frequentlyy fill the 56 with 110 leaded. It loves it, I love it, it smells great, runs great.
Old 07-13-2013, 10:36 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
As said that stuff is garbage. When it says it raises it 3 4 points or whatever it really means from 91 to 91.3
Been using this it works real well and they will ship to Ca.
Run 11.5:1 on the street never pings. On 91 octane 34 deg was pushing it run closer to 40 now with this.
I dont drive it much so 1 six pack goes a looong ways.
http://www.wildbillscorvette.com/OctaneSupreme01.htm
Of course good race gas probably better (mixing it)
Old 07-13-2013, 11:41 PM
SS409
SS409's Avatar
- Mark
Well that answers my question about mixing lead and ethanol, thanks...
Old 07-13-2013, 11:43 PM
SS409
SS409's Avatar
This stuff sounds interesting. I may give it a try. Thanks for all your help guys....
Old 07-13-2013, 11:49 PM
SS409
SS409's Avatar
Tom, that's one expensive fill up 110 here is 10.00 a gallon. It must be nice to have money to burn, literally.
Old 07-14-2013, 12:14 AM
DZAUTO
DZAUTO's Avatar
The 56 is NOT, repeat, NOT a daily driver. The price for 110 leaded here is about $7/gal now. When I feel extravagant, the 56 gets a healthy dose of 110.
At other times, I use 91octane NON-ethanol, which is quite common around here.
Old 07-14-2013, 12:38 AM
wmf62
wmf62's Avatar
St. Jude Donor '07
every once in a while i used to mix 2 gallons 112 leaded non-ethanol with 13 gallons of 93 unleaded ethanol in my 62 when i was running the rochester injected LT1.
the engine loved it, no percolation problems on the hottest summer day; and it smelled sooooo good..
but, too expensive to run on a routine basis.
Bill
Old 07-14-2013, 09:17 AM
SLWRNU
SLWRNU's Avatar
Being in Kaaaalifornia you do know that since you've used the word "lead" that you are now on the official state watch as being an enviromental scofflaw.
Keep looking over your shoulder my friend.
Old 07-14-2013, 09:24 AM
ohiovet
ohiovet's Avatar
2016 C1 of Year Finalist
I use 93 octane (Shell brand) with ethanol in my original 1962 340 HP 327 which has a 11.25 to 1 compression ratio.
No detonation or any other fuel related problems.
The Shell dealer tells me that the fuel usually has up to 10% ethanol but the wonderful state of Ohio does not require that the ethanol content to be disclosed on the pump.
Old 07-14-2013, 09:52 AM
burtonbl103
burtonbl103's Avatar
St. Jude Donor '06-'07-'08 & '12-'13
I run the 110 LL in my fuelie. It loves it.
Some time is will mix 2 gallons of 93 sunocco to 5 gal of the ll
Old 07-14-2013, 10:13 AM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
If the engine has been blueprinted to get an actual 11-1, you MIGHT have a problem with it. If the heads/block have been just slightly surfaced and used stock compression height pistons in it, you won't have that much compression.
Before I spent money on expensive fuel, I'd check the spark curve and see what it yields. If it meets factory spec I wouldn't think you'd have a problem running 91 octane gasoline at all. But, I've never run any California 91 so don't really know.
In the meantime, my two engines that are similar to yours run fine on 89octane E 10 but they don't have aggresive spark curves in them.
Old 07-14-2013, 10:28 AM
Mike Ward
Mike Ward's Avatar
If the NOS octane booster (a known placebo) is curing the problem, I think the solution is obvious.
Old 07-14-2013, 10:34 AM
wmf62
wmf62's Avatar
St. Jude Donor '07
and that is???? the engine is psychosomatic?
Bill
To 110 octane "leaded" gas
Old 07-14-2013, 10:50 AM
Mike Ward
Mike Ward's Avatar
No, not the engine.
Old 07-14-2013, 10:52 AM
ohiovet
ohiovet's Avatar
I have used 100LL in my 57 fuelie but after changing to Shell 93 I find it runs fine and starts hot and cold with no problems.
It is a 4360 unit which I have been told won't run good regardless of the fuel but Bob Williams of Sidney, Ohio has tuned it perfectly.
Old 07-14-2013, 11:15 AM
MikeM
MikeM's Avatar
That is Shell 93 E 10? Correct?
Quick Reply: 110 octane "leaded" gas
