Need a picture Deck lid 1965
Hi Guys/Girls, I need a picture of a 1965 deck lid hardware. I'm reassembling after some paint work and need reference photo of hardware on area nearest door. I have an idea what goes there, but want to make sure. I'm also looking at the AIM. Picture give me a better prospective. Thx Chuck
Received 1,857 Likes
Everything on the underside of the convertible deck lid was installed in the Body Shop, prior to paint, and the underside of the lid and all the lid release hardware was sprayed body color.
Sullyvette (05-07-2017)
Thanks Bill, I'm looking for the stainless trim pieces (bolt/screw)actually attached to the deck lid. A round threaded bolt. It would fill or cover the holes shown in my first picture. I should have taken a picture of that stainless bolt. Can you believe I'm sending this at 4:02 am. The things that keep us up! Or is it just old age? Thx, Sully
The following 2 users liked this post by Critter1:
6T5RUSH (05-09-2017),
I have the hardware, maybe I never noticed the second hole when I dissembled. On one side it is mostly covered by the one bolt, no so much the other side. What would be the best way to fill at this point? I just had the deck lid painted? Thx, Sully
Sully, do you have 2 large holes like that on either side of your deck lid?
1st question: do you have a hard top?
If yes, and it was me, I'd be fiberglassing those extra holes in, and then you'll have to repaint. The hole to leave is the one (probably the foward-most one in your pic) which is 2" from the front edge of the panel to the center of the hole. See my 66 deck lid.
If no, I'd be filling them all in and repaint.
Good luck with the repair. Cheers, Bill
Sullyvette (05-08-2017)
I do have two holes on each side, what ever possessed them to do that is beyond me. One set is 2" (center of hole) from the end of the lid and the other is 2 & 1/2 " from the lid. No, I don't have a hardtop and won't be getting one. Thx, Chuck
Well Chuck if your not going with a hardtop and filling those holes on each side, since you'll need to repaint the deck lid, I'd also fill the 2 holes (~ 1/2" in dia) in the top, rear surface of the deck lid to which are also used to hold the hardtop down. Cheers, Bill
Sullyvette (05-09-2017)
Hi Bill, I think I'll keep the hardtop hold downs on the lid. That's what it came with. I did fill the EXTRA holes on the lid near the doors. Turned out pretty well. Last nights adventure. pics to follow!
