-65 Vette runs 193,4MPH on standing mile!
Here's another neat video about the car. It's a Finnish car show called "virittajat" I guess you could translate it as "gearheads". It's a funny (to Finns) show, hosted by Mika Salo, the Ex-Ferrari F1 driver. He drives different "gearhead" cars, with the owners standing nervously at the pits waiting for their cars to arrive back in piece after M.Salo tests them out. They give them score on performance, looks and Wow-factor. This car won the whole 2nd series, Salo absolutely loved the whole package and this was couple of years ago, with the old engine, suspension and brakes, so it would be cool to see it run once again.
Usually when people start building these cars they set their aim on one particular thing, some like it to be a show stopper, some like it to do well on a 1/4 mile strip, some like it to have a lot of top speed, some just like theirs to be nice cruisers, some might like their cars to be relieble for long journeys. This car does all of that and then some...
You really need to see and hear this car to really appreciate it. Jack Panzica got to see the car and met the owner on his trip to Europe and was well impressed by it.
Very cool car, with cool numbers to back it up.
I believe it started out as a off the shelf Ecklers C2 spoiler, which was afterwards widened and lowered some, not much but just enough to make it work. The trick part is underneath the car + the new air intake system, really made a big difference to last years time.
Here's the car back in 2011, running 11.8 with the old motor. I can't wait to see what he'll do it with the new motor this year.
TheFin (03-03-2021)
Here's last years video, 179mp/h then with the whole different motor, no real aero mods, besides the front spoiler.
TheFin (12-19-2023)
TheFin (12-19-2023)
That's where the troll comment came from. The OP should post all the facts up front. Then he won't get those comments.
Dave
"Latest for this summer was the Aero package, which is really trick and will only be visible underneath the car,"
Write up states Aero package only visible form underneath car. Sounds like he's figured out how to stop underneath air flow from building up under the hood and causing front end lift. The air dam on the front I'm sure helps some as well as it looks like he has back end of car sitting above rear tires, while nose of car sits down over front tires. Hard to tell from picture if and how much the rear tire's dia may be over front in Standing Mile form. Drag race form, it does have larger dia rear tires to nose front down.
You can easily raise rear of car 3.0" higher than front and still have the body cover the tires the same amount. Just look at stance of Lydia, it's done that way. Lydia's running the same base designed spoiler, except it's been widen 2.0" and ends moved out about 3/4" to center of turn signals. Lydia has not lifting problems at 152 MPH in her 1:1 Gear.
That car has one hell of an engine to overcome the 4.0' x 8.0' sheet of plywood in a huricane aerodynamics of a C2 body to push it to 193.344 MPH.
kph: 311.3 = mph 193.344
First post I saw on car was on digital corvette by member there since 2005.
http://www.digitalcorvettes.com/foru...d.php?t=178186
What is the fastest speed you have heard of C2 doing in standing mile? My friend Kimmo in Finland just did 311,3kmh/193,4mph. This is one fast 65. No supercharged. Old school V8 with fuel injection and NOS. His hope was to break 300km/h (186,4mph), but he managed to go little over. I bet Zora never tought C2 could go this fast. Here is pic of the car at Joensuu Airfield where he did his record. So far fastest non-supercharged car here in Finland.
What an amazing Vette. It sounds like the best-developed, most thoroughly sorted Sting Ray ever. Congratulations to the owner and those who helped him. It will be fascinating to learn details of the engine, suspension and aero.
#33
Not sure what he did underneath the car, i am very curious. Could be mods based on the Ferrari 360 Modena ,and later Enzo that had massive air ducts to evacuate air from under the car and give it negative underbody pressure.
Doug
Doug
#34
4-7 and 3-2 swap to be exact. Development engineers at comp cams are very aware of potential this cam has
Here is one more video. Stage 1 engine, making 640hp without NOS. After that Kimmo took apart the engine and started to tickle out some power for the stage 2 he's running now
#35
Thanks to the OP for giving us more, now post up some pics of the bottom of the car.
One last question. Who runs a car with 200 mph potential without a cage?????
#36
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
Awesome car! I can't wait to see the enging specs and pics of unside of car. I'd also like to see a pic of the drag strip timing lights with those numbers after the runs, if they use those over there.
I'm a little confused though? Is 193 the top speed of the car in the mile, or the quarter mile? Seems like the ET would have to be in the 7s or less, to get that top in the quarter. Title is a tad confusing to me. Thanks.
#37
