1967 windshield wiper motor won't run
Old 07-05-2013, 09:00 PM
fccjr42
1st Gear
fccjr42's Avatar
Default 1967 windshield wiper motor won't run
I used Willcox instructions to test wiper motor on 1967. Connected center contact to battery. Jumped yellow terminal connection to ground. Motor won't run. Jumped light blue terminal connection to ground. Motor won't run. No voltage at yellow terminal connection. Voltage at light blue terminal connection. Wiper motor case is grounded until I unplug other wiper motor plug (brown & dark blue). Now what should I check?
Old 07-05-2013, 09:17 PM
66jack
66jack's Avatar
The first question should be/Is, did it ever work before you started testing?
And
Did you replace wiring and now have the issue of not working?
Old 07-05-2013, 10:15 PM
GreaseMonkey
GreaseMonkey's Avatar
PA Events Coordinator
Second test from my experience, if it was rebuilt and sitting a while, tap the bitch with your finger. The lube inside probably hardened. Dr Sky65 figured that out on mine
Old 07-05-2013, 10:27 PM
66jack
66jack's Avatar
Originally Posted by GreaseMonkey
Second test from my experience, if it was rebuilt and sitting a while, tap the bitch with your finger.The lube inside probably hardened. Dr Sky65 figured that out on mine
now thats funny....
Old 07-08-2013, 10:22 AM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If the motor is still in the car, disconnect everything (including the ground) from the motor. Run jumper wires to the motor including a new ground. Test again. If it fails you need to have the motor rebuilt.
Willcox
Old 07-08-2013, 06:11 PM
ooh yeah
ooh yeah's Avatar
Willcox
that gives me chills, had to remove mine twice no fun on a Tri power. Good luck hopefully the tap trick works otherwise don't bring her to Fl. because you'll need them.
Old 07-08-2013, 11:21 PM
0Willcox Corvette
Former Vendor
Its best if you remove the nut from the bellcrank inside the car. This way you don't dry wipe the windshield.
Doing this and running 1 jumper hot wire to the motor with a couple of grounds is easier than removing the motor.
Willcox
0Willcox Corvette
Former Vendor
Willcox
To 1967 windshield wiper motor won't run
Quick Reply: 1967 windshield wiper motor won't run
