Need advice on Vacuum Advance hose on Holley 2818
Cruising
I need help with a Holley 2818 I just bolted to my 64 Vette 327 / 365 HP.
I don't know where to attach the Vacuum Advance hose. I think it should go to the front side Metering Block? - But that hole has been plugged up.
Also, I don't know what the other holes are for??
Thanks - John
Thanks - John
Received 1,859 Likes
Thanks - John
Thanks - John
On the driver's side, the hole in the center of the main body is threaded for a restrictor fitting that accepts a 3/8" PCV hose to the bung welded to the oil fill tube. Without that restrictor fitting, it will be a HUGE vacuum leak.
All of this is shown in your Assembly Manual, section L76, sheet 3.00 and 4.00.
Photos below show the correct installation - it's a '65, but it's the same as '64..
Cruising
JohnZ,
Thanks VERY MUCH for the photos!
They show me what I must do now.
Another Question: I have the old Holley 1850 Carb (It does have the correct port), can I take that metering block off and stick it on my newly installed Holley 2818 - Would that work??
Thanks - John
Thanks - John
Cruise-In II Veteran
Cruise-In III Veteran
That hole on the side. I have a 66 327/300 A.I.R. 3605 carb with it and one without it. It’s also on my 66 427/390 car. None of mine have the fitting in it the hole is not open. So my question is which of the 3605 carbs are Correct bad as this on all corvette Holley carbs but not used on various engines like mine?
So, I have one 3605 carb dated for a late production 1966 327/300 A.I.R. car with that hole and two 3370 carbs dated for a early production 1966 427/390 car with that hole. Are these carbs original for these NCRS cars or will they not work on these NCRS cars. Did these carbs possibly come out on these cars?
662 (3605) 327/300 a.i.r.
653 (3605) 327/300 a.i.r.
591 (3370) 427/390
591 (3370) 427/390
JohnZ,
Thanks - John
Thanks - John
