Muncie Trans Tag# 3880833 Help!
Old 06-14-2013, 07:00 PM
Paverman
Paverman's Avatar
Default Muncie Trans Tag# 3880833 Help!
Can someone help with any info on Muncie trans tag #3880853 ? its on a 1966 corvette BB with 4speed and 4:11 gears. other numbers that ive decoded so far 3885010, 3857584. Also on the bell housing the number is 3858403 with a larger number 7 above that set, and I cant find any info for the bell housing numbers? should they match anything? please help.
Last edited by Paverman; 06-14-2013 at 07:32 PM. Reason: realized i got tag number wrong.
Old 04-30-2014, 11:32 AM
Paverman
Paverman's Avatar
bump
Old 04-30-2014, 01:50 PM
5thvet
5thvet's Avatar
Here is some good info and discussion on that tag...
http://forums.corvetteforum.com/c1-a...ranny-tag.html
Don
Old 04-30-2014, 02:06 PM
DZAUTO
DZAUTO's Avatar
Received 3,768 Likes on 1,670 Posts
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
I've never been much of a numbers person, thus, I don't keep up with the tag numbers attached to Muncies.
But one thing I'm quite confident about is the bell housing is not a match for your big block. The 010 main case is correct for 66-67 Muncies and the 584 tail housing is correct for 65-70 Muncies.
With the exception of the 65 Corvette with a 396 BB, ALLLLLLLLLL 66-later BB Vettes got the BIG bell housing and the larger 168 teeth flywheel.
So, for a 66 with a BB, the bell housing SHOULD be the big 3872444 for the larger 168 teeth flywheel. Beginning with the 67 models, the big bell housings were 3899621. For all practical purposes, the 444 and 621 housings were identical.
The 403 housing was the smaller housing, used with ALLLLLLLLLLLLLLL 65 engines (including the 65 396 BB) and ONLY with small blocks in 66.
Yes, that's right, for 66, there was a large and small flywheel and bell housing.
Old 04-30-2014, 02:51 PM
Velox
Support Corvetteforum!
Velox's Avatar
Well FWIW my L72 has a tag #3880855 which from what I have found is the correct number for 66 M21 big block. Your number is listed as the tag on M21 small block cars
Old 04-30-2014, 05:29 PM
leaky4150
leaky4150's Avatar
Don't venders sell trans tags?
To Muncie Trans Tag# 3880833 Help!
Quick Reply: Muncie Trans Tag# 3880833 Help!
