Question on Removing a Power Steering Pump Pulley
1 Post
Hello,
I have a chance to sell a 66 Corvette small block power steering pump with brackets to a guy in Australia. He told me that my pump pulley will not work on his 72 small block 350 (non air). He needs a different pulley. I have never removed a pulley off a power steering pump. Concerned about damaging the pulley.
My question: How does one remove the pulley off a power steering pump?
All replies will be greatly appreciated.
Richard
Richard
P/S Pulley
Hello,
Richard
Richard
RON
1 Post
Thanks for the information. There is a nut holding the pulley. I will try to remove the nut with a socket wrench. There is a square part behind the nut on the pulley shaft for a crescent wrench to fit on. I don't want to put the pulley on a vice, because I will bend something. When the pulley nut is removed, will try to tap out the pulley lightly with a rubber mallet.
There's a special puller that grabs the hub of the pulley and removes it without any stress on the pump shaft. Most auto parts stores will loan/rent you one. Or if you walked in with your pump, they'll probably just pull it off for you - no charge.
Pulley
You're going to damage the pump if you tap on the pulley.
1 Post
Finally took off the pulley. Had to use a impact wrench and a vise grip to remove the nut. The pulley did not come off easily. I had to heat off the pulley with a propane torch and tap with a hammer gently on a block of wood. The rubber mallet was ineffective. Took about 45 minutes to do. Looks like the pulley was pressed on along with a key way.
Check the '66 service manual, which clearly cautions against beating on the pulley or shaft to avoid pump damage.
