C2 pumpkin change out
Old 05-22-2013, 06:53 PM
mrg
mrg's Avatar
Default C2 pumpkin change out
In addition to Chuck's current pumpkin change out back to 4:11's, I'm also looking to do the same - only in reverse............4:11 to 3:08. A big change, to be sure. .. Looking to install the 3:08's for some long distance highway cruising up to WA state, and then some.
What I would like to do is swap pumpkins out with a minimum of connecting parts removal. The idea being to possibly 're-swap' pumpkins when the driving season is over.
After drive shaft removal, strut rods, etc., do the half shafts have to be completely removed?. Can the U-joint/flange on the inboard side only of the half shafts be disconnected, leaving the outboard ends still connected to the axle shaft flanges?. Does this leave enough room to effect pumpkin removal?
The plan is to also leave the rear cover in place and unbolt/bolt in the replacement pumpkin back onto the cover. Also looking to install a gear ratio adapter in place of removing the trans and rear housing to change out the drive/driven speedo gear set.
Any tips much appreciated. .. Thanks
John
Old 05-22-2013, 07:00 PM
Chuck Gongloff
Support Corvetteforum!
Chuck Gongloff's Avatar
John
PERSONAL opinions only. Others my disagree.........
I think it's real tough to separate the diff case in the car. Others have done it.
You can either reach over the top with a 5/8" 6 point socket and remove the 4 diff cover bolts and drop it that way or you can pop the X member off of the sombrero bushings and drop the entire rear that way.
Yes, it makes things easier to completely remove the half shafts. You're only talking 8 more bolts. You can then get them out of the way.
I think you'll create a stinky mess separating the case, dousing yourself in that wonderful smelling gear oil.
Chuck
Old 05-22-2013, 10:27 PM
mikey
mikey's Avatar
If you seriously want to switch back and forth between ratios, I'd seriously consider a quick change rear. Unless you just have a lot of free time and like taking the rear suspension and drivetrain apart
Old 05-22-2013, 10:50 PM
Bluestripe67
Bluestripe67's Avatar
Received 2,125 Likes on 1,464 Posts
[QUOTE=mikey;1583968741]If you seriously want to switch back and forth between ratios, I'd seriously consider a quick change rear.
I can't comprehend that someone would have this thought...unreal! Dennis
Old 05-22-2013, 11:04 PM
mikey
mikey's Avatar
[QUOTE=Bluestripe67;1583968931]
I think John spelled it out pretty clear in the other thread, but perhaps not.
To C2 pumpkin change out
Quick Reply: C2 pumpkin change out
