electric fan
electric fan
I would like to add an electric puller fan to my '66 327/300 non AC car.
I would like to be able to operate it manually for parades etc, when the car is being driven real s l o w on summer days .
Any hints or suggestions as to brands , size , installation , etc ??
Over heat, impossible
Did you find out why your car is overheating. Or you just want to throw parts at it until its fixed. Oh sorry, that was another thread. There are members on here who say if the car is correct original with everything working as should, car will not over heat. Of course that's people who live in Alaska and only drive during Christmas holidays.
My mechanic added one from a newer corvette. Works great. My 66' 427 BB was running too warm before the install (I also added different thersmostat and flushed the radiator and block so I had other issues which were causing it to run warm). Took the car to Palm Springs last week driving back in 100 degree temp and although it ran warm, it never over heated (I don't think the BBs vetttes were meant to run in those condtions anyway--not a lot of room in the engine bay and the mid year vette does not allow a lot of air to get in the bay (even with the front plate off)). m
I put a Derale in mine but not because of any overheat problems, I went to a serpentine belt configuration and since the water pump is now reverse rotation, the stock fan won't work.
I went with a Derale that included a plenum, something that I felt was important since I have A/C and wanted to pull air across the full area of the condensor. Mine's actually a two speed model and is setup for the low speed to engage with the A/C compressor and high speed is controlled by a thermostatic switch in the water jacket.
I have another electric fan I bought that fits in the opening of the stock shroud but decided to clean up the engine compartment and get rid of that huge hunk of metal. It's for sale if anyone is interested.
i'd leave the engine shut off for parades, if parades is your thing.
i'd use a scooter motor to power the car via a small wheel under the car, a temporary install just for parades. BUT, that is me, i don't expect anyone to do this, it is too much fun. You guys must do it the non-fun way, it is in your DNA
Fan
If you are going to mount the fan in front of the radiator, you will need a pusher fan as opposed to a puller fan. If you put in front, get one that is very thin. If not, your hood may hit the fan when open. Jerry
I want to use a puller so it is hidden by the shroud . Thanks EDinPA for the disgram . now all I have to do is buy a fan that will fit .
Even tho it's the central coast of calif , it gets HOT here in the summer time . Over 100 deg + . I do like to drive the car in cruizes or parades once in awhile and it can get to hot with no air flow .
Right now the car runs about 185 on the freeway and going around 45 in town , but slow down and it starts to go over 200 .
You will love the electric fan; no more constantly checking the temp guage. Make sure all the other components are okay--clean block and radiator, correct thermostat, etc. I know its not legal but I took off the front license plate and left it that way despite having added the e fan. Driving around San Diego the car now runs very cool with the e fan.
You need a LOT of airflow from a fan..get the most cfm you can. Also be aware of the hi amps drawn by them..you need heavy wire and good alternator output..a stock 37A might be marginal.
Make sure the fan shroud seals around the rad too
Correct re the shroud--mine had issues which also contributed to the running too warm issue. If there is one area where a lot of little and not so little things end up causing a big problem, it's the cooling. I think the C2 BB vette cooling was barely adequate from the factory (in my humble opinion); does not take much to make it inadequate. marty
