BB hood fresh air induction
Old 05-11-2013, 04:37 PM
Bluestripe67
Support Corvetteforum!
Bluestripe67's Avatar
Received 2,127 Likes on 1,466 Posts
Default BB hood fresh air induction
.com/user/Bluestripe67/media/DSCN3676_zps6b089fb5.jpg.html][/URL]
I know some of you guys have talked about making the BB hood functional. Since I have mastered the photo thing here on the CF, here are the shots of what I made for my car and the details. SB w/Edelbrock Performer intake, Edelbrock 625CFM carb, dropped base air filter, 3" filter, and standard GM distributor/cap/wires. The hood is a GM issued replacement. Look at the shot of the backside of it and you can see the specific ribbing/reinforcements around the perimeter. I removed the three ribs at the back side (see the yellow tape markers) so the air would have a smooth entry path. I do not know about modifying a production hood. I guess you can do the same cut, but you will have to close the open ends, no big deal. First effort I mocked the unit up with cardboard to get height numbers (used modeling clay) for hood clearance. Second effort I got some scrap sheet metal and did the mockup and finally with all the specs and fit just right I took it to a sheet metal fabricator for the final that you see in the engine shot. The foam was bought at the Army/Navy surplus store and cut to fit. This fresh air induction made a big difference in performance and drivability. You will need to re-jet your carb due to the nice cooler air coming in. Dennis
Old 05-12-2013, 01:41 PM
Marks69BB
Marks69BB's Avatar
Or you could bond in the L88 airbox from Ecklers like GM did for cowl induction back in the day:
http://www.ecklerscorvette.com/corve...hood-1967.html
You would also need the L88 air cleaner base setup (below on my 69) which means your air filter goes up inside the airbox.
Old 05-12-2013, 02:17 PM
Bluestripe67
Marks69BB, your installation deals with factory components where mine are aftermarket integrated parts resulting in the custom build. The principal of function and results remains the same...free HP. Dennis
Old 05-12-2013, 02:43 PM
toddalin
toddalin's Avatar
Received 1,167 Likes on 486 Posts
So you can't use it with the ignition shield?
It doesn't look like you could squeeze a whole lot of air through that small area above the cowl in the back. And of course you recognize that a factory BB hood is nothing like that on the underside.
Old 05-12-2013, 02:55 PM
Bluestripe67
toddalin, I stated the difference in hoods in my OP. True...you can't use it with shielding! I have no way of knowing the CFM flow from the opening. I can tell you that it must be enough. It made a very noticeable difference in low end torque because when I went to the track (previous runs 13.5, 13.6) a second time I couldn't get the tires too hook through 1st into 2nd and turned 14.1, 14.3. That proved my point of free HP/TQ from the fresh air induction. Dennis
Old 05-12-2013, 04:02 PM
Marks69BB
Marks69BB's Avatar
Dennis: I agree this is all factory stuff; just another option for those who have original 67 BB hoods but the airbox could be integrated into any aftermarket hood with some fab work to get the benefit of cowl air induction. It made a huge difference on my 69 with the 555!
Here's a pic of a real 67 L88 hood compliments of an older JohnZ post:
Before bonding in the airbox, the stock BB hood whould have to be cut out above the rear support for cold air cowl induction.
Old 05-12-2013, 04:24 PM
Bluestripe67
That's a great shot of an orig. BB/L-88 hood. Is it fun playing with these cars or what? Dennis
Old 05-12-2013, 06:44 PM
GreaseMonkey
GreaseMonkey's Avatar
PA Events Coordinator
Looks interesting Dennis. Nice work
Old 05-12-2013, 07:05 PM
65tripleblack
65tripleblack's Avatar
Now, the REAL puzzle would be how to get cool air induction using a '65-'66 BBC hood.
I have ideas in mind, but not mocked-up yet.
Trick!
Old 05-12-2013, 07:33 PM
ren
ren's Avatar
My 63 had a BB hood with the front cut out to allow air flow.It was OK , but not totally functional. Has the car painted last year so I bought a new BB hood. I found a part in Ecklers cat, called " fresh air induction". It has to be molded to the under side of the of the hood and it fits pretty tight around the air cleaner. It looks great and works great. If I ever figure out how to take pictures, I'll post a few.
Old 05-12-2013, 09:41 PM
Bluestripe67
If I ever figure out how to take pictures, I'll post a few.[/QUOTE]
Ren, Go to the latest post up top in the stickies section about posting pics. Thats how I learned and succeeded on this post. Trick was using the tutorial on my laptop beside the desktop PC. Dennis
Old 05-13-2013, 01:48 PM
toddalin
toddalin's Avatar
Trick!
Here you go.
Old 05-13-2013, 03:00 PM
magicv8
magicv8's Avatar
You also need to rework the whole thing to get it to line up with a small block.
you can't just slide the air box back.
Old 05-13-2013, 03:21 PM
magicv8
magicv8's Avatar
using a '65-'66 BB hood.
The screened hole at the front of the center aluminum panel is in the high pressure area in front
of the rubber A-C hood seal, when the hood is down. The screen is needed to minimize incoming
bugs. No holes were drilled to mount the aluminum panels. It made an incredible difference, since
the heat coming from the A-C unit in front of the radiator was no longer entering the carburetor.
Old 05-14-2013, 09:40 AM
65tripleblack
Here you go.
That looks great, and has been and still is a possibility for me.
My goal is getting it to function without any external modifications, which means drawing air through the a chrome side grills.
Old 05-14-2013, 09:42 AM
65tripleblack
I'm happy it works for you.
I'm not smart enough to follow what you did, though.
Old 05-14-2013, 09:46 AM
65tripleblack
I can't find it.
To BB hood fresh air induction
Old 05-14-2013, 11:49 AM
magicv8
magicv8's Avatar
I made a cardboard template, then took a piece of sheet aluminum and bent a double step in it to step over the hood frame. At the front of the hood is a hole to let cold air get in. The A-C hood seal hits the aluminum just in back of the hole when the hood is down. At the other end the cold air comes out of the 3 inch gap between the aluminum and the hood, right in front of the air cleaner.
The steel rain shields for the hood grilles were exchanged for aluminum pieces that also let cold air in to the air cleaner.
Cardboard templates were cheap and the aluminum was bent on the edge of my work bench.
Old 05-14-2013, 12:12 PM
Matt Gruber
Matt Gruber's Avatar
can also remove the rubber flaps over the A frames and plumb cold air there(inside the wheel well).. not so good on dirt roads or in a downpour making sharp turns imo.
Old 05-14-2013, 02:47 PM
65tripleblack
Thanks!
The hole in the front of the hood sounds good. Like a modern Z06.
I'll keep that scheme in mind.
Quick Reply: BB hood fresh air induction
