66 Engine harness - where's home for this wire ?
Bubba...:d
Received 2,127 Likes
Does look like shade tree electrical. Dennis
Received 1,857 Likes
Took the tape off the wires. They're black wires and 1 of them has a 3rd black wire spliced & soldered into it. The 3rd black wire is a heavier gauge than the other 2.
I noticed when connecting the starter/solenoid harness that there were only 3 wires going to it instead of 4. I wonder if the heavier gauge black wire I found under the tape could have originally gone to the starter/solenoid ?
The car does have a ballast resistor. It's not mounted in the right location. It's on the firewall on the passenger side of the distributor.
The previous owner told me the alternator was wired wrong by a shop and when he tried to start the car the harness was fried. He had to get a new alternator. Unfortunately he elected to go without a voltage regulator- the alternator he had installed only has a single wire going to it. So eventually I'll get a new harness, correct alternator & replace the voltage regulator. In the meantime I'll see if these orphaned wires will bolt onto the bellhousing.
Thanks for everyone's input.
I like the "Shade Tree Electrical" comment.
Ryan, If those wires are dead cap them off and hide the ends. You don't want the appearance of "Shade Tree Electrical". I wouldn't attach them to anything. Regarding the voltage regulator. Consider an electronic one for installation. No contacts inside, solid state electronics, same connections for installation and trouble free operation. Dennis
