Water Pump Belt install - What's the secret?
Old 04-30-2013, 01:30 PM
Larry N. Johnson
Larry N. Johnson's Avatar
Default Water Pump Belt install - What's the secret?
I knew this would be a challenge.
How is this possible?
Water pump to crankshaft pulley, no idler.
Yes, the 65 BB is that way.
How on earth can one get the w.p. belt on without ripping it?
Old 04-30-2013, 01:34 PM
Tampa Jerry
Tampa Jerry's Avatar
Received 1,328 Likes on 960 Posts
Default Water pump
My small block had the same issue. If I remember, just tap the engine over and it should slip on. Remove the coil wire just in case and keep your fingers and that of a helper away just in case. Jerry
Old 04-30-2013, 01:40 PM
Mike Ward
Mike Ward's Avatar
Remove the four nuts that hold the fan clutch to the water pump. Tilt/move the pulley so that the belt slides easily into it's groove. Re-install the hardware.
Old 04-30-2013, 01:52 PM
nassau66427
nassau66427's Avatar
Location: going faster miles an hour...with the radio on in browns mills new jersey
I don't know how others do it but the way I do it is like this:
Unbolt the bottom pulley.
Place the belt onto the water pump pulley and the bottom pulley.
Loosely install one bolt in the bottom pulley in a hole near the top of the pulley.
Using a small phillips screwdriver as a lever, place it through a bolt hole on the pulley and into the corresponding hole in the balancer.
Push it downwards enough to allow the installation of a bolt in the remaining open hole and snug that bolt down.
Tighten the first bolt installed.
Remove the screwdriver and install the third bolt.
Old 04-30-2013, 01:57 PM
Ironcross
Ironcross's Avatar
Does this car have power steering?.....no way is a belt attached to the engine by a fancy method from the factory......something is missing or its routed incorrectly
Old 04-30-2013, 02:12 PM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
You must be new to Corvettes!
Old 04-30-2013, 02:15 PM
wombvette
wombvette's Avatar
Must be.
Old 04-30-2013, 02:17 PM
Larry N. Johnson
No Power Steering.
No Air Conditioning.
Just an alternator and a water pump.
Maybe more HP that way?
Old 04-30-2013, 03:15 PM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
I've used both methods in post #2 and #3 above at various times and either should work.
Old 04-30-2013, 03:22 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
Bill
Old 04-30-2013, 03:38 PM
Larry N. Johnson
Mike, that way worked fine. Thanks.
Old 04-30-2013, 03:47 PM
Plasticman
Plasticman's Avatar
Method in post #2 is hard on the bearings (water pump and 1st main), and not doing the belt any good.
Post #3 is the "only" way to do it.
Congrats!
Old 04-30-2013, 04:38 PM
MikeM
MikeM's Avatar
Mikey has a C3 which I believe some of them have studs in the water pump flange instead of bolts. That makes it simple. On the other hand, for those of us that have bolts in that application, temporarily putting a couple of studs on the water pump flange until you get the belt pulley installed makes it super easy.
Old 04-30-2013, 04:53 PM
Mark Lovejoy
Mark Lovejoy's Avatar
Larry,
Looks like you got it.
I noticed you don't have a spacer under the thermostat housing. ??
Old 04-30-2013, 04:59 PM
Ironcross
Ironcross's Avatar
Originally Posted by wombvette
Must be.
Yep, I didn`t know it was that obvious, and how about you gentlemen .....got one?..
Old 04-30-2013, 05:23 PM
babbah
Support Corvetteforum!
babbah's Avatar
On my BB the exact same way - Ive done it this way many times over the past 46 years!! Fun Fun Fun
Old 04-30-2013, 07:12 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
Originally Posted by Mark Lovejoy
Larry,
no spacer??? i THINK i see one....
Bill
To Water Pump Belt install - What's the secret?
Old 04-30-2013, 07:25 PM
babbah
babbah's Avatar
Is it me or is that pulley mighty close to the water pump? Looks like it is almost hitting that nice orange paint. Just checking
and no heater eh???.
Old 04-30-2013, 07:53 PM
Larry N. Johnson
Mark Lovejoy,
No spacer under the thermostat housing, correct.
Ordered housing thermostat and bolts from Long Island.
The bolts seem about the right length.
Is the spacer supposed to be in there? Purpose?
Old 04-30-2013, 07:59 PM
Larry N. Johnson
Yes, it is close!
I would estimate 1/8" clear.
Quick Reply: Water Pump Belt install - What's the secret?
