Water Pump Belt install - What's the secret?
Old 04-30-2013, 08:24 PM
Nowhere Man
Nowhere Man's Avatar
Received 6,920 Likes on 4,770 Posts
2015 C2 of Year Finalist
I thought the captive belt went on the inside and the alt belt on the out side
Old 04-30-2013, 08:28 PM
66jack
66jack's Avatar
Originally Posted by wmf62
no spacer??? i THINK i see one....
Bill
he was talking about post 11....
Old 05-01-2013, 07:00 AM
4 Speed Dave
4 Speed Dave's Avatar
Not on a 65, yes on 66-up.
Old 05-01-2013, 07:32 AM
Kerrmudgeon
Kerrmudgeon's Avatar
Received 4,583 Likes on 2,157 Posts
C1 of Year Finalist (appearance mods) 2019
For tight belts I've always got them half on with a screw driver and then ticked over the motor to finish the job. Easy peasy.
Old 05-01-2013, 07:35 AM
Mark Lovejoy
Mark Lovejoy's Avatar
Originally Posted by Larry N. Johnson
Mark Lovejoy,
No spacer under the thermostat housing, correct.
Ordered housing thermostat and bolts from Long Island.
The bolts seem about the right length.
Is the spacer supposed to be in there? Purpose?
Larry,
The spacer is to allow clearance for the temperature sending unit. I looked for a better picture that shows the sending unit. I'll look again, this is assuming you have the correct intake manifold.
Old 05-01-2013, 07:45 AM
Mark Lovejoy
Okay, I found one. Not the greatest angle but I think it shows what I'm referring to. There would be interference between the sending unit and upper radiator hose/clamp without the spacer.
Old 05-01-2013, 09:24 AM
wib1961
wib1961's Avatar
"OUOTE"The spacer is to allow clearance for the temperature sending unit. I looked for a better picture that shows the sending unit. I'll look again, this is assuming you have the correct intake manifold.
What years use that spacer? I don't remember one on my '61 and always thought it was a tight clearance from the hose to the temp. sender
Old 05-01-2013, 09:28 AM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
I've used the 'bump the engine till belt drops in groove' method for decades. If your adjustment bolts are loose when you do it then I doubt it does anything to bearings (or they were bad to start with).
Old 05-01-2013, 09:32 AM
Nowhere Man
Thanks that explains that
Old 05-01-2013, 09:49 AM
Mark Lovejoy
This is a 396 engine, I don't think it's applicable to small block engines.
Old 05-01-2013, 10:44 AM
Larry N. Johnson
Larry N. Johnson's Avatar
Default 396 Temp Sender Clearance
Mark,
This engine has an aftermarket manifold, and "RPM Performer".
In looking closely, it looks like the temp sender if I had a short one one like yours, would fit without the spacer.
Thanks for the info!!
LNJ
Quick Reply: Water Pump Belt install - What's the secret?
