Generator rebuild
Old 04-29-2013, 01:54 PM
coyote19
coyote19's Avatar
Default Generator rebuild
I want to have the generator rebuilt /repainted and the correct tag attached. Any recommendations where to send it? Thanks, Chris
Old 04-29-2013, 02:45 PM
Larry P
Larry P's Avatar
They did mine and the water pump over 12 years ago.
I don't know about the correct tag as mine still had the original.
You can call and ask.
JAY AT BILT RITE GENERATOR CO
2507 E SULLIVAN
St.Louis, MO 53107
314-421-0875
Old 04-29-2013, 05:22 PM
Donald #31176
Donald #31176's Avatar
Don Briggs in Lighthouse Point, Fl or John Pirkle in Augusta, Ga should be able to do the job.
Old 04-29-2013, 05:34 PM
Redbird
Support Corvetteforum!
Redbird's Avatar
2021 C2 of the Year Finalist - Unmodified
C2 of Year Finalist (stock) 2019
2016 C2 of Year Finalist
Your local old timer shop can do it. The tags are available at CC. I had one done at a local shop for $65. Charges just fine.
Old 04-29-2013, 05:37 PM
Rickb1873
Rickb1873's Avatar
Depends on what you want. If you are looking for a functional rebuild, then you can find a local electrical shop that can do the job very inexpensively.
If you want an NCRS correct restoration as well as an OEM functional rebuild then the only one I can recommend that I have personal experience with is John Pirkle Jr. Absolutely top notch.
smokdfsh (01-10-2016)
Old 04-29-2013, 07:19 PM
1955 copper
1955 copper's Avatar
2015 C1 of Year
What year???
Old 04-29-2013, 08:14 PM
Ironcross
Ironcross's Avatar
Originally Posted by 1955 copper
What year???
it don't make any difference if hes having his existing core rebuilt...more important, where is the core geography..as we build the best available...Heavy core!
Old 04-29-2013, 10:51 PM
coyote19
coyote19's Avatar
Just a functional rebuild. I don't know how many times its been painted so basically just wanting checked out and cleaned up. Thanks for the responses. I'll see if there is someone local.
Old 04-30-2013, 08:52 AM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
The guy that rebuilt my '61 starter here in Orlando said they don't see many generators anymore but he'll rebuild mine if needed. I bet most such shops still have the skills.
However, these guys might not have a clue where the red tag should be mounted or even care to do it.
You can order one of those red tags online stamped with whatever you want and cut off the stems of the two rivets and JB Weld the assembled tag to the proper spot on the generator and save yourself some drilling and a chance to screw something up. On a non-judged car nobody will know the difference.
Old 04-30-2013, 09:37 AM
toms silver 60
toms silver 60's Avatar
whatever you do, don't lose the pulley! It took me 30 years to figure out mine had been swapped, and a chance visit to the now closed repair shop revealed the right size pulley, perhaps even my own.
To Generator rebuild
Quick Reply: Generator rebuild
