62 fuelie question
Old 04-25-2013, 07:27 PM
Jermo
Jermo's Avatar
Default 62 fuelie question
I have a question, I have a 62 fuelie, I was wondering if you can re route the vent tube back to the oil fill tube? so it doesn't blow oil under the car? Just wondering. Has anyone tried this?
Jerry
Old 04-25-2013, 07:53 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
you can use a PCV and route the 'vapors' from where the road draft tube hole is to the plenum. here is the pic of the California setup,
Bill
Old 04-25-2013, 07:55 PM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
Sending the crankcase vapors into the oil fill tube is not really what you want to do....one of the points of the road draft tube (or even more modern PCV systems) are to scavenge corrosive (and EXplosive!) vapors out of the crankcase. The road draft tube vents the vapors to the atmosphere; the PCV (option RPO-242 on our cars) reburns the vapors by sucking them into the carb base...
I don't know where you put the PCV valve on a fuelie but you will want one of these adapter for the hose from the road draft hole to the PCV valve....Paragon has them.
Old 04-25-2013, 08:00 PM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
Jerry
If you have a LOT of smoke and blowby coming out of the draft tube, maybe you oughta' invest in a set of pistons rings.
Otherwise, Wm 62 has you on the right track.
Old 04-26-2013, 12:21 AM
Jermo
Jermo's Avatar
Bill
Thank You Bill,
This is exactly what i'll do. Not that I have a lot of blow by, just don't like the hose just hanging there.
Old 04-26-2013, 09:05 AM
wmf62
wmf62's Avatar
St. Jude Donor '07
the California system is a bit 'ugly'... if you are good at tubing bending you can probably bend up a tube that will go between the distributor and the plenum and then use rubber hose on either end to the adapter shown in Frank's pic and to the plenum/PCV end. i bent up something similar to connect to the PCV i used when i was using LT1 valve covers. i believe it can be done.
Bill
Old 04-26-2013, 09:31 AM
DZAUTO
DZAUTO's Avatar
Received 3,766 Likes on 1,669 Posts
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
OR,
Old 04-26-2013, 10:15 AM
Jermo
Jermo's Avatar
Originally Posted by DZAUTO
OR,
That's awesome, kind of a no brainer, Thanks for the pictures and the idea
Old 04-26-2013, 10:20 AM
wmf62
wmf62's Avatar
St. Jude Donor '07
Tom's is the cleanest way to do it.. my suggestion is best if you are going to draw from a PCV installed in a valve cover.
Bill
To 62 fuelie question
Quick Reply: 62 fuelie question
