65 electrical schematic for dummies-me
Looking at the IGN - run circuit I am confused, IGN 18 B/P runs to coil + through what I believe is ballast resistor (funny looking symbol) which I assume is for the start circuit, but the coil + is also fed of the R terminal on the starter which I assume is for the run circuit. If I'm correct then how does engine stop, something to do with horn relay?
Alright i got it backwards sorry, thats why said for dummies, R on starter must be full voltage for only energized for starting and IGN must be reduced voltage for running...
QUOTE=mrh12000;1583695750]Looking at the IGN - run circuit I am confused, IGN 18 B/P runs to coil + through what I believe is ballast resistor (funny looking symbol) which I assume is for the start circuit, but the coil + is also fed of the R terminal on the starter which I assume is for the run circuit. If I'm correct then how does engine stop, something to do with horn relay?[/QUOTE]
So the real question is if IGN is hot when I'm cranking, can I power my MSD directly from it?
QUOTE=mrh12000;1583695774]Alright i got it backwards sorry, thats why said for dummies, R on starter must be full voltage for only energized for starting and IGN must be reduced voltage for running...
QUOTE=mrh12000;1583695750]Looking at the IGN - run circuit I am confused, IGN 18 B/P runs to coil + through what I believe is ballast resistor (funny looking symbol) which I assume is for the start circuit, but the coil + is also fed of the R terminal on the starter which I assume is for the run circuit. If I'm correct then how does engine stop, something to do with horn relay?[/QUOTE][/QUOTE]
You can hook the red wire to the side of the ballast resistor that goes to the ignition, but not to the side that goes to the coil.
