Panel Adhesive
Panel Adhesive
I have a new front end coming for my 62.
I'm used to fiber-glassing everything, but have used SEM 39747 dual-mix panel adhesive for metal to fiberglass. 90 min work time and it sticks rather than runs...
Would this me a good panel adhesive for bonding strips, etc?
Or any specific recommendations?
The 8115 is very good to work with. You get a stable work time, and unlike the old style bonding adhesive, you can clamp (if you need to) tight, and still get the same strength. Older bonding required a minimum of 1/4" material (glue) to get full bonding strength.
Mike Coletta
Mike Coletta
I ended up getting SEM 39747. I have used it in the past for metal to fiberglass.
I spoke to an industrial fiberglass manufacturer here in Phoenix. He said I could use it for fiberglass to fiberglass too. I had a few tubes of it left over here at the house. It is pretty thick and should work with a similar work time ad the 3m 8115.
