66 Vette pwr window switch pocket avail. ?
Just removed the Muncie in my 66' roadster. I broke the plastic
switch pocket that holds the power window switch (just behind the shifter). Is it available as a reproduction? Its a very tight clearance
trying to pull that tranny out... tailshaft hits the power window switch plastic pocket... I'll probably break it again!
Couldn't find it in the catalogs!
http://www.parts123.com/parts123/yb....Z5Z5Z50000050B
Corvette central has them
Whose your favorite supplier?
Long Island 15-26A
http://www.parts123.com/parts123/yb....5AAAFI~Z5Z5Z51
Corvette Central 592206
Paragon Corvette 4699K
https://www.paragoncorvette.com/p-34...-brackets.aspx
Long Island 15-26A
I couldn't find the part in the catalogs...maybe I'm calling it by the wrong name!
Its the plastic pocket that is glued onto the fiberglass console. Its about 1" x 3" looks
like a plastic tray that the switch & wires fit. It would probably be only on models with the power windows. Can't seem to find it!
Transmission tailshaft seems to hit it when I drop down the tranny.
Disregard the PM I sent you this AM...
GB has them listed...
