Evans Waterless Coolant
#41
A gallon of water, a gallon of prestone and a gallon of Evans coolant will all expand at the same rate (more or less) when heated. If you installed the Evans coolant in your engine, the system will still come up to the 7 or 13 lbs as controlled by the rad cap. To achieve the pressureless system they promote you'd have to modify the rad cap to avoid building pressure.
Just because it can operate successfully at zero pressure without boiling over or inducing cavitation doesn't necessarily mean it's a good thing.
Making a 0 psi system by modifying the radiator cap has been easy in the engines I have converted.
#42
The Ford guys have us beat by about 10 years with this stuff. It was written up in Muscle Mustangs anf Fast Fords magazine in 2003 or thereabout. It's non-aqueous propylene glycol. Completely safe and non-toxic (it's actually used in food processing). Other than the expense, the only downside is that the stuff has to remain completely free of water to get the high boiling point benefits. It's also available from Amsoil.
Evan's recommends less than 5% water, with ideal being 1%-I've also seen 3% as being ideal.
Amsoil antifreeze recommends mixing with water, but it is propylene glycol based.
#43
I am really interested in understanding if this is really worth it looking at the responses!!
If I stay with the old fashion way what is the recommendation on the ratio of water to antifreeze?
Thanks,
Stephen
Thanks,
Stephen
#44
The "environmentally safe" and "pet-friendly" anti-freezes (like "Sierra", etc.) are propylene glycol-based, and when mixed 50-50 with water, are about 10% less efficient in terms of heat transfer based on our OEM testing many years ago than conventional ethylene glycol-based anti-freeze coolants. Don't know about GM or Ford, but Chrysler has a warning in their owner's manuals against using propylene glycol-based coolants due to the reduced cooling capacity that results which can lead to engine damage not covered by the warranty.
#45
Frankie,
Just because the system does not operate at pressure, does not mean that it does not need and expansion space, I think Mikey was responding to the idea of removing the expansion tank over the battery. You would still need to keep the expansion tank to handle the expansion, and serve to scavenge air from the system, and serve as a place to fill the system. The corrosion inhibitors do not settle out of the antifreeze, they are consumed. We almost never change out antifreeze on our large diesel generators, we just replace the corrosion inhibitors as they are consumed. We have a test kit that tells us the level in coolant. Antifreeze never wears out, it just loses it's corrosion inhibitors.
With all the new coolants being good for 5 years, I will just stay with conventional coolant. I would doubt that you would ever see a payback from the use of this stuff. We have used Polypropylene Glycol in chillers for years, because it is not at all uncommon for a chilled water system to have at least several hundred to several thousand gallons of coolant, so a spill would be toxic. That being said, Polypropylene Glycol has less cooling capacity then Ethylene Glycol, and substantially less than the 50/50 mix that most of us use. The only thing it brings to the table, in my opinion, is long life, but the high price makes that a non-starter for me.
Regards, John McGraw
#46
I'd say it depends on what you want your boiling point and freezing points to be, based first on manufacturers recommendation. Make sure your rad cap holds recommended pressure too. Most cars I've had recommended 50/50 mix
#48
#49
I googled "What percentage of engine repairs are coolant system related" and the first website states "A majority of engine repairs are coolant system related" I came across the statistic I referred to, or something close, several times in my studies of coolants a couple years ago. If you really would like to know, call Evans and ask for independent data references. They're going to be the quickest reference, but I can also refer to Balwin filters web site and go thru their coolant tutorial, I found that to be quite helful.
#50
Well, I think the supplemental coolant additives (SCA)flake off the walls of the cylinder, as they are present to form a sacrificial layer to the cylinder wall. (liner) The cavitation pulverizes the SCA's. This crud floats around damaging impellers and internal coolant pathways, which is why some install coolant filtration. Oh I'm aware that some of the crud is manufacturing scarf, but one can get precipitates to some degree...
Sure, but that is an issue with any coolant. That is why you check the DCA on a regular basis.
#51
Sure, engines break down when they overheat, that is a given. What I find fault with, is your assertion that PG is any better than EG as to keeping an engine cool. If a radiator hose blows, the engine is going to overheat, regardless of the coolant. A properly maintained cooling system will keep an engine cool, regardless of the coolant. The only real plus I see of PG, is it's low toxicity, but that is more than offset by it's high cost. Most of the studies that I have read on PG, also say that the life is shorter because of a higher oxidation rate, which forms acids, and higher head losses, because of the inherently higher viscosity. This would equate to lower coolant flow through the system.
If you like PG, I am surely not going to try and dissuade you from using it, as it will clearly do the job, but I do not believe that it is superior in all regards to EG antifreeze.
I am not at all adverse to spending more money for a product that has clear, benefits to my application, but I do not find PG to have such benefits. I do not have issues with my cooling systems, so I have no need to spend several times the cost of my current coolant, to fix a problem that does not exist. I have no doubt that it works well for you, but what I do doubt, is that your cooling system works well because of the PG. A problem cooling system is going to be a problem cooling system, and I have never seen any evidence (marketing hype excluded), that such a problem can be fixed by changing to a different coolant.
#52
I Googled 'what percentage of gullible people believe that everything they read is true' and the interweebs said it's 100%.
Good luck.
#53
If that's the depth of your 'research' and given your apparent willingness to blindly accept such 'data' as proof, you fall into the demographics targeted by all the snake oil vendors.
Good luck.
Good luck.
Why is this percentage important to you? Whether it is 50% or 70%, it's not a material fact and won't be an issue for most of the people on this forum, considering all the other potential benefits to the coolant.
I am not going to do your research for you, and I don't care if you believe me because I don't make one cent off Evans coolant. I did the research for myself and didn't keep a bibliography because I'm not writing a book. I do know a little about you though, assuming you are not fibbing, you haven't done the research and are argumentative.
I believe everyone should do their own research, and make up their own mind. I simply made points for everyone to consider that they may not have considered before. Hot rods run hot, Corvettes run hot, they're not cheap and this coolant may be an answer, or at least part of it.
#55
Received 1,856 Likes
Here's all you need to know about Corvette cooling systems:
http://www.lbfun.com/warehouse/tech_...em/cooling.pdf
The cures for cooling system issues don't come in bottles - they come in boxes.
#57
But this is exactly my point, SCA's are added to protect against cavitation due to water being present in the coolant. If there is no water, there is no cavitation, and no need to check the coolant additives. Similarly the corrosion inhibitors, added to protect against the corrosive effects of the water, wear out and need to be replaced. With Evans, there is no need to check the additives, perhaps you can check for water contamination with a refractometer, but it's likely not needed after the initial install.
#58
No, they don't, and no "answer" is required when there's no question to begin with; you are fervently seeking a problem that doesn't exist in order to apply an expensive "solution" that's unnecessary.
I've seen a dyno sheet where the only parameter change was switching to Evan's and the engine picked up a bit of torque across the entire curve. That idea might be of interest to members of this forum. The theory is that even temps contribute to better flame front travel.
I am currently having Mark at VortecPro assemble an engine, and I will be there for the dyno. I'll ask him to pull back to back dyno runs, one with traditional coolant and one with Evan's, and post the results if it of general interest to the forum.
#60
St. Jude Donor '13-'14-'15-'16
Unless all test runs have the results corrected to SAE standards your back to back results are not worth much for data or proof of gaining horsepower over conventional coolant.
And yes you will still need expansion room even with Evans coolant. Or get a bucket to catch the outflow of hot coolant.
We (where I work for a living) ran tests for over two years at a customer's request, they paid the bills too, on using Evans. They're not now and will not be in the future be using Evans. But hey, they only design and build engines and vehicles for a living and we test, develop, certify them for our living. Draw your own conclusions.
