SB ride quality? 460lb spring vs stock 293lb
I have a 63 small block and want to replace the stock (sagging) springs with 460's (F41). I understand the handling will be better with the 460's but am concerned about a harsher ride. I don't want to sacrifice much in ride quality. For those that have made this switch was there much of a difference in ride quality? thanks.
Actually, for a "comfortable" ride, I found that the reverse is true, and plain vanilla Monroe shocks softened the potholes when I removed the KYBs.
I bought KYB GR2 and couldn't stand them. Very stiff ride IMO. Unless you plan on road racing, I would get the small block 9 leaf spring from Eaton, and get the Monroe, Gabriel Ultras, or Delco Advantage shocks. I have the Delco gas shocks , and they are a little stiffer than than the base Monroe, but they are acceptable IMO. By the way, last I heard, Gabriel makes Delco shocks. You wil pay a lot more for Delco, than you would if you walked into AutoZone and bought the Gabriel Ultras..
I have already replaced the rear leaf with a 330# monospring and Delco Professional gas shocks all around. It has been a nice upgrade, but need to replace the saggy front coils. I would like to go with 460's but the tech at Corv Central says the 460's will make for a considerably firmer ride, which I would like to avoid. Are the 460's really going to be that much harsher? Thx.
Ditto on the KYB's
