2-Post Lift for Mid-Year, Any Problems?
Old 02-22-2013, 09:25 AM
cordova67
cordova67's Avatar
Default 2-Post Lift for Mid-Year, Any Problems?
Does anyone know of any concerns using a 2-post lift on a mid-year? Was told that it causes too much stress on the doors and could cause cracking of the fiberglass at the top of the door. Comments anyone?
Old 02-22-2013, 09:34 AM
Mr D.
Support Corvetteforum!
Mr D.'s Avatar
Received 1,486 Likes on 1,003 Posts
None that I'm aware of and have used one many times on C-2 and C-3's.
Old 02-22-2013, 09:38 AM
cordova67
cordova67's Avatar
Thank you for the response.
Old 02-22-2013, 10:52 AM
jrm5657
jrm5657's Avatar
2022 C2 of the Year Finalist - Modified
For a midyear convertible on a 2 post lift, I always leave the doors unlatched, the body will flex slightly. On a coupe, no worries with the doors.
Old 02-22-2013, 10:56 AM
Mike Terry
Mike Terry's Avatar
Also pop the latch on the hood cheap insurance to prevent stress on the hood. May want to do it to the rear deak if you have a Vert. Anything that will open on a Vette when lifting it on a 2 post lift you need to open or at least pop or release the latch so there is no stress put on any fiber glass.
Old 02-22-2013, 11:16 AM
cordova67
cordova67's Avatar
Makes sense. Good information, thanks to each of you.
Old 02-22-2013, 11:43 AM
jdk971
jdk971's Avatar
my friend a mechanic always pops my coupes doors open. just to
be safe. on his two post lift. jim
Old 02-22-2013, 03:00 PM
wombvette
wombvette's Avatar
Two post lifts in my shop for 30 years, no problems. I have a rusty frame 65 on one right now, the door gaps look like I-95. Still no problems.
bob68 (09-28-2023)
Old 02-22-2013, 06:19 PM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
The only way I think you could do any damage is if you had a rusty frame just about to snap by picking it up on the rusty spot with the overhand behind the pickup point.
What is the difference between picking up the car AHEAD/BEHIND the normal load bearing points or when the car hits the road and then you hit a bump?
Old 02-22-2013, 07:08 PM
MikeM
MikeM's Avatar
As far as unlatching doors, when I was a grease rack jockey in 1963, if you got a steel car two door hardtop up on the rack, the doors would stick and a four door hardtop was even worse. Some of the doors on the four doors wouldn't even open! No permanent damage though.
Unlatching the doors on a rack is something the weenies started way back then. No problem unless there is something basic wrong with your car to start with.
Old 02-22-2013, 09:31 PM
Plasticman
Plasticman's Avatar
No problems at all with my 62 soft top, and I have never unlatched anything except the hood, which stays unlatched all the time it is in the garage for battery turnoff switch access.
Plasticman
To 2-Post Lift for Mid-Year, Any Problems?
Quick Reply: 2-Post Lift for Mid-Year, Any Problems?
