Hood clearance for this smallblock and recommendations, please...
Old 02-21-2013, 02:14 PM
BioRxOkc@aol.com
BioRxOkc@aol.com's Avatar
Default Hood clearance for this smallblock and recommendations, please...
I just bought a 65 smallblock roller and am looking to put a crate motor in...
I would love to have recommendations from the group on what some good options may be...
Car is a 4 speed M21 with a 3.08 rear. Not looking for anything more than a fun cruiser and occasional run through the gears...
I was deciding between:
1) GM 350/260 (pretty good torque with 350 ft/lbs)
http://www.jegs.com/i/Chevrolet-Perf...353K1/10002/-1
or step up a little to this:
2) GM 350/290 (better HP but less torque)
http://www.jegs.com/i/Chevrolet-Perf...529K3/10002/-1
Third option seems like a good motor for the car:
3) GM 350/330 (needs more parts to complete)
http://www.jegs.com/p/Chevrolet-Perf...31165/10002/-1
But, if I spent that much, I could get a more complete and much stronger 350/350
4) GM Circle Track 350/350
http://www.jegs.com/p/Chevrolet-Perf...52396/10002/-1
So, what are some thoughts AND WOULD THAT LAST 350/350 MOTOR FIT UNDER A SMALL BLOCK HOOD?
Thanks in advance!
Old 02-21-2013, 02:45 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
yep, don't see why it wouldn't fit, seems to be same size as the ZZ4, will depend on what aircleaner you use; and, i doubt the oil pan will fit...
Bill
Old 02-21-2013, 02:56 PM
John S 1961
John S 1961's Avatar
Whats your budget?
Old 02-21-2013, 04:17 PM
Scott Marzahl
Scott Marzahl's Avatar
Any small block should fit, just depends on the intake and aircleaner combo used. Also the oil pan may need to be replaced for one compatible for Corvette application.
Old 02-21-2013, 06:32 PM
BioRxOkc@aol.com
I was skeptical about that pan fitting, but I went ahead and bought the 350/350...
Couldn't find anything else that could match it with a factory warranty for $3150
Now I need to decide on some good shorty headers to stick on to mate up with the side exhaust...
Old 02-21-2013, 06:40 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
for what it's worth, and it shouldn't be a problem for you, those are sealed engines with special bolts/fasteners that are tamper-proof so that race officials can verify that it has not been modified.
Bill
Old 02-22-2013, 02:12 PM
FastEddy
FastEddy's Avatar
Dont go shorties !!!!!!! Headman makes an excellent set of full length headers that point towards the factory side exhaust. They also have the modern "ball joint" type collector, so no gaskets are needed there, and they come ceramic coated. They fit great, and do not stick down any farther than the oil pan !! - unlike normal full length headers that have to clear the starter. They are worth every penny. Sadly, I bent up a set in an accident years ago. Unfortunately I cant find a pic on this computer of them out of the car.
I still have a set of stock type sidepipes with the ball joint collector end on them for just this purpose if anybody wants them. Also have a set of bent 2.5" sweet thunders with the ball joint end, if anybody wants to cut and paste those back together. one side is bent in front of the muffler, the other one has a mashed tip. Cheap.
Old 02-23-2013, 05:55 AM
Crunch527
Crunch527's Avatar
Fast Eddie is right...I too have the Hedman coated side pipe headers...they are sweet. No interference, and I had a local shop fab my side pipes to fit the headers.
I dont have a pic but here is the link to summit...they aren't too spendy either
http://www.summitracing.com/parts/hed-68286
Frank
Old 02-23-2013, 08:02 AM
MarkC
Support Corvetteforum!
MarkC's Avatar
C2 of Year Finalist (performance mods) 2019
You may want to look for a M20 trans. It has a 2.54 first gear as compared to the 2.20 in the M21. The M21 is going to be hard on the clutch getting started. Another option would be to replace the rear gear with a 3.55 or 3.70. The best option is a 5 speed. Good luck.
Old 02-23-2013, 01:55 PM
FastEddy
FastEddy's Avatar
Best thing about a 3:08 rear is that if you dump the clutch in first gear with a 350/350 (I had ZZ4), you will get an instant rear wheel speed of about 60mph...which means if you are willing to hang on, the tires will be spinning until the car catches up with that wheel speed.... helluvalot of fun...
With the lower first gear in my 5spd and 3:55 rear, I have to use second gear for that....
To Hood clearance for this smallblock and recommendations, please...
Quick Reply: Hood clearance for this smallblock and recommendations, please...
