Original key identification
Old 02-16-2013, 02:00 PM
emdoller
emdoller's Avatar
Default Original key identification
My 67 came with several keys. How do I know if any of them are original?
Old 02-16-2013, 02:09 PM
Nowhere Man
Nowhere Man's Avatar
Received 6,943 Likes on 4,782 Posts
2015 C2 of Year Finalist
do any of them say Briggs & Stratton on them
Old 02-16-2013, 02:31 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
The original ignition/door key is octagonal, says "Briggs & Stratton Corporation" on the left edge and "Milwaukee Wis. USA" on the right edge, and the knockout has the 4-digit key code stamped on it. The reverse side has "GM" and "your key to greater value" on it, and the shank has "A" stamped on it.
The rounded glove box/spare tire lock key is the same, except it has a "B" stamped on the shank on the reverse side.
Old 02-16-2013, 03:19 PM
emdoller
emdoller's Avatar
Here are front and back pics of the three that say Biggs and Stratton:
Old 02-16-2013, 03:22 PM
JohnZ
JohnZ's Avatar
Looks good to me.
Old 02-16-2013, 03:26 PM
emdoller
emdoller's Avatar
Originally Posted by JohnZ
Looks good to me.
Thanks John. As always, I appreciate your insight.
Old 02-16-2013, 03:28 PM
62Jeff
62Jeff's Avatar
Without any stamping on the knock-out plug of left key, would that be original to the car - or simply an original-style copy?
Old 02-16-2013, 03:30 PM
emdoller
emdoller's Avatar
Good question. By the way, what does the number mean?
Old 02-16-2013, 03:40 PM
JohnZ
JohnZ's Avatar
Without the key code stamping on the knockout, it's a duplicate key cut on an original blank. The 4-digit key code describes the key cut, and is also stamped on the barrel of the matching lock cylinder. With that 4-digit key code, a locksmith with a Curtis key-clipper can make an exact duplicate key, if he has a correctly keyway-coded blank.
Old 02-16-2013, 04:03 PM
emdoller
emdoller's Avatar
So glove box is original and the ignition/door is a remake on original blank
Old 02-16-2013, 04:06 PM
JohnZ
JohnZ's Avatar
That's correct.
Old 02-16-2013, 05:00 PM
1974purchase
1974purchase's Avatar
Default cannot be too careful
Old 02-16-2013, 05:27 PM
emdoller
emdoller's Avatar
Thanks. I wonder why the one key has the center section cut out? I'll keep looking for the other key.
Old 02-16-2013, 05:38 PM
Powershift
Powershift's Avatar
Received 1,681 Likes on 1,307 Posts
They are very easy to find/buy on Ebay. The key blanks for 1967 are "A" and "B". Then have a local locksmith cut the key(s). That is what I did.
If you want original keys, already cut, and with the codes stamped etc, then there are a few guys that can do that as well. Some are $ and others are $$$. Let us know if you want their names, etc.
Larry
Old 02-16-2013, 06:29 PM
JohnZ
JohnZ's Avatar
Back in the day, dealers routinely removed the knockouts so they could put the keys on their promotional key ring (the hole in the knockout was too small for a conventional key ring), or kept them in the "deal folder" so they had the key numbers in case they (or the financing bank) had to repossess the car.
Old 02-16-2013, 06:39 PM
emdoller
emdoller's Avatar
Larry
Larry
Let me know as i wouldnt mind getting one.
I'm pretty sure the keys I have are original but I wouldn't mind having one made with the number on it. I just looked at the original welcom folder that came with the car and on the inside it has a plastic card with the original owners name, the vin number, and on the bottom the key number.
Thanks - Ed
Old 02-16-2013, 06:52 PM
JohnZ
JohnZ's Avatar
Ed -
PM sent.
To Original key identification
Old 02-16-2013, 07:23 PM
Powershift
Powershift's Avatar
Ed -
PM sent.
If JohnZ has provided the names and phone numbers for the guys that do this work that is great. If not, just let me know.
Larry
Old 02-17-2013, 01:05 PM
Ironcross
Ironcross's Avatar
I have the code books and the key cutter to make the exact copy,
Old 02-17-2013, 01:10 PM
Powershift
Powershift's Avatar
Can you (or do you) also stamp the key codes into the key knockout like OEM??
Larry
Quick Reply: Original key identification
