Soda or Plastic Media Blaster Northern Virginia
Old 02-12-2013, 04:17 PM
IMSA GTO
IMSA GTO's Avatar
2023 Corvette of the Year Finalist - Modified
2022 C2 of the Year-Modified
Default Soda or Plastic Media Blaster Northern Virginia
Appreciate any comments or suggestions on soda or plastic media blasting shops in the Northern Virginia or DC area that are knowledgeable in stripping mid years. Anybody with good or bad experiences who can recommend a shop? ( or ones to stay away from)
Old 02-12-2013, 05:12 PM
bluzrocker
bluzrocker's Avatar
Saw your post ..my resent exp...is....I have 67 BBC roadster ready to get new paint.
Got a choice of chem strip...soda....# 6 acrilic beads....chose the bead blast....to reveal all defects...and for my painter to garentee his BLACK/W RED stripe only if we take paint entirely off....so what kind of paint job are you getting??
I got a driver no warranty + all panels..( needed front valance turn signal panel and all the bonding strips......7500.00 and I take it down and put it all back cept painter will install the head lights and weatherstripping...
now when I get done ...everything is fixed undernieth and a solid lasting warrantyed paint job... 10.000
BUT...blasting a metal car v/s a fiberglass one is totally different....the blaster must have experiance on glass ....possible out come super wavey body panels....all eadges of body must be taped and hand worked later..all holes are skipped and musr be worked by hand so not to destroy the edges..etc...mine was done by experianced blaster and came out pretty darn good.....has lots of vette experiance...so be clear when you dip stick blasters..make sure they know this ISNT A STEEL BODY
and another good thing on the beads ......very little residue left after mine was done.........compared to soda blasting....but then that depends if the car is totally stripped w/ all interior out ...or just preping body for new paint....lots to consider...let us know what your thinking now..
Bluzrocker
Old 02-12-2013, 05:35 PM
IMSA GTO
IMSA GTO's Avatar
Thanks for your comments Bluzrocker. This is exactly why I am looking for forum members experienced with local shops in my area. The last thing that I want is a pile of glass fibers that used to be a C2 body.
Old 02-13-2013, 07:54 AM
JBL Specialty
JBL Specialty's Avatar
I send the cars we do to asco in manassas,they do a great job and no problems. They have done 5 or 6 vettes for me their number is 703 368 9922 jbl
Old 02-13-2013, 08:06 AM
IMSA GTO
IMSA GTO's Avatar
Thanks John, I will give them a call
Old 02-13-2013, 01:50 PM
RoadKing96
RoadKing96's Avatar
Location: Holly Springs, Nort Cackalacky / Jupiter, Florida
I had my '64 Soda Blasted at the same time a friend had his all original, numbers matching '63 Fuelie Soda Blasted. It took our guy about 3-4 hours to complete both.
Both cars were on Dollies and both came out great. We have since cleaned, prep'd and applied high build primer. Now repeating the sanding, prime, sand, prime until ready for paint.
I would recommend Soda Blasting a fiberglass body. For the price vs. time saved even setting your sanding/stripping time at a conservative $20/hr was well worth it.
Picture of both, back into shop after Soda blasted.
RK
To Soda or Plastic Media Blaster Northern Virginia
Quick Reply: Soda or Plastic Media Blaster Northern Virginia
