542” Tri-Power motor, cast iron exh.manifolds – 671.05 rwhp through mufflers!
Old 11-23-2011, 06:23 PM
632C2
Support Corvetteforum!
632C2's Avatar
Default 542” Tri-Power motor, cast iron exh.manifolds – 671.05 rwhp through mufflers!
The car is a 1967 Corvette convertible.
All of the runs were made with the factory 1967 tri-power intake manifold, factory cast iron exhaust manifolds, a custom fabricated 3” exhaust system, all accessories connected (including clutch fan), and power steering.
Here are the numbers from the DynoJet:
STD: 671.05 rwhp / 633.45 rwtq
SAE: 652.77 rwhp / 616.20 rwtq
Uncorrected: 671.87 rwhp / 634.23 rwtq
Some of my friends want to know what that equates to in flywheel horsepower. I hear a lot of people talk about 15%-20% for manual transmission cars.
If you take 15% the numbers become the following:
STD: 789.47 flywheel hp / 745.24 flywheel tq
SAE: 767.96 flywheel hp / 724.94 flywheel tq
Uncorrected: 790.43 flywheel hp / 746.15 flywheel tq
If you take 20% the numbers become the following:
STD: 838.81 flywheel hp / 791.81 flywheel tq
SAE: 815.96 flywheel hp / 770.25 flywheel tq
Uncorrected: 839.84 flywheel hp / 792.79 flywheel tq
There are some people on this forum that insist Corvettes eat up well over 20% due to the independent rear axle.
For any purists out there, I am not trying to pass the car off as an original 435 hp 427 Corvette. It is a 327 car pure and simple. I will freely admit this to anyone who asks. The more I thought about trying to make a tri-power setup produce big numbers, the more I wanted the challenge. Making this combination run with factory exhaust manifolds just added to the challenge.
My goal with this combination is to have it appear factory correct under the hood. I also happen to have a 1967 Corvette coupe with a 632" motor that looks nothing like stock under the hood. I wanted to do something different this time. I have taken a great deal of time trying to make things appear stock. Most everything for this conversion was purchased from Paragon Corvette Reproductions.
This car originally came with a 350 hp 327. I put a 383” motor in it around January of 2006. With cast iron exhaust manifolds and 2-1/2” exhaust, that motor made 416.47 rwhp / 430.4 rwtq and went 11.93 at 114.99 mph in the quarter. (BTW, the 383” motor is for sale.)
The gold color you see on the top of the exhaust manifolds are a result of the exhaust manifold paint I purchased from Paragon. I painted the entire exhaust manifold with this product. It starts out gold and then as they heat up they change to a cast iron color. Since the temperature of the exhaust manifold is lower the closer you are to the exhaust flange of the head, the longer it will take to change colors.
The motor consists of the following: Chevrolet Bowtie block, Dart *highly disguised* 335 CNC heads, Jesel valvetrain, Mike Jones solid roller cam, Isky EZX roller lifters and valve springs, BRC crank, Howards I-Beam rods, J&E pistons, Total Seal rings, Clevite 77 bearings, Dan Olson oil pan, Holley fuel pump, and a trio of *SPECIAL* Holley 2-barrel carburetors.
I have made 52 DynoJet runs to get to this point. My first run was on October 20th, 2011 and the final run was on November 20th, 2011. I have tried everything within reason including moving the cam timing 4 separate times. I am not talking about ignition timing here. Anyone who has moved the cam timing on a motor that doesn’t have a belt drive while the motor is in the car can attest to the amount of work it requires. The entire front end of the motor has to come off every time.
I'm sure I left a bunch of stuff out but this is a start. I have a friend that owns a machine shop that bored, torque plate honed, align-honed, and decked the block to my specifications. He also balanced the rotating assembly. Everything else was done by me. This includes the assembly and necessary massaging of the components in the motor. For instance, since I now have a mill and a lathe, I was able to flycut the pistons and machine my own pushrods. I also made significant modifications to the oil pan and fabricated the 3" exhaust system including making my own 'X' pipe. The exhaust system consists of (2) DynoMax bullet mufflers and (2) DynoMax Ultra Flo oval mufflers run in series.
One last thing. I will be drag racing this car this spring. (Sorry for the long-winded post.)
Steve
Old 11-23-2011, 06:27 PM
62Jeff
62Jeff's Avatar
Ummmmm, holy chit?!?!
That's amazing work.
Old 11-23-2011, 06:36 PM
provette67
provette67's Avatar
Wow great job
Old 11-23-2011, 06:38 PM
5thvet
5thvet's Avatar
Very impressive~~~~~~~
Old 11-23-2011, 06:44 PM
Kerrmudgeon
Kerrmudgeon's Avatar
Received 4,583 Likes on 2,157 Posts
C1 of Year Finalist (appearance mods) 2019
What are the specs on the cam? Can't wait to hear it run. Great sleeper until you hear it run I'll bet! What quarter times are you expecting with street tires? Great camo job....
Old 11-23-2011, 06:46 PM
65-StingRay
65-StingRay's Avatar
632C2;
Well you sure "impressed" the hell out of me. That's real healthy power.
Don't worry if you thought it was long winded. I'd like to hear more about that project of yours.
65-StingRay
Old 11-23-2011, 07:00 PM
Plastic Pig
Live Free or Die
Plastic Pig's Avatar
Location: One thing is for sure this kind of discourse and BS would not be tolerated on the NCRS forum. Ohio
Originally Posted by 65-StingRay
632C2;
65-StingRay
Cool project. Looking forward to seeing it in action. Don't forget the vids.
Old 11-23-2011, 07:11 PM
claysmoker
claysmoker's Avatar
St. Jude Donor '09-'11-'12-'13-'14
Very nice.
What are you doing for a rear end that will live?
Old 11-23-2011, 07:19 PM
provette67
provette67's Avatar
you had better buy stock in a tire company it looks like you are going to need it
Old 11-23-2011, 09:52 PM
632C2
632C2's Avatar
Originally Posted by provette67
Wow great job
Thanks guys!
Steve
Old 11-23-2011, 10:02 PM
632C2
632C2's Avatar
The cam specs are 254*/258* @ .050", .701"/.700", 114 LSA. It sounds as close to the stock cam in a 435 hp 427 as myself and a couple of friends can remember. Nothing radical in any way, shape, or form. This thing is shockingly smooth.
I will be running Mickey Thompson DOT radials. Hopefully they will get the job done.
Thanks again.
Steve
Old 11-23-2011, 10:04 PM
632C2
632C2's Avatar
632C2;
65-StingRay
Between this thread and the one in the C3 section, you will probably get all the info you would like.
Thank you for the kind words.
Steve
Old 11-23-2011, 10:08 PM
632C2
632C2's Avatar
Originally Posted by claysmoker
Very nice.
Here is a link that will answer your question.
http://forums.corvetteforum.com/c3-t...onversion.html
Steve
Vette5311 (08-01-2018)
Old 11-23-2011, 10:57 PM
Donny Brass
Donny Brass's Avatar
C2 of Year Finalist (track prepared) 2019
2017 C2 of the Year Finalist
very well done.....
I love a lot of power out of a stock looking car
Old 11-23-2011, 11:10 PM
632C2
632C2's Avatar
Originally Posted by Donny Brass
very well done.....
Thanks, Donny. My inspiration for this car was the F.A.S.T. cars. I know you know something about them.
I just wish I knew more details about their cars. I lurk on their forum trying to glean information but to no avail.
Steve
Old 11-23-2011, 11:49 PM
claysmoker
claysmoker's Avatar
Steve
Thanks, saw that thread before but didn't put it together with you. That will hold the HP OK. Is the car tubbed or do you have flares to contain the tires you'll need?
Old 11-24-2011, 12:42 AM
vetrod62
vetrod62's Avatar
Wow, great numbers. It has been a long time since we have talked and have not seen your posts on the c1 forum. I am looking forward to you setting some new records at F.A.S.T. racing.
BTW, if you are going to use the TKO-600 trans as in the linked post, it will cost you big time in ET. I dumped mine after 3 years of racing, and that included mastering the 2-3 high speed/fast shift. I picked up .3 seconds with a M-22W. Jim
To 542” Tri-Power motor, cast iron exh.manifolds – 671.05 rwhp through mufflers!
Old 11-24-2011, 02:41 AM
babbah
babbah's Avatar
What makes the carbs "special"?
Old 11-24-2011, 06:56 AM
BarryK
BarryK's Avatar
well, they aren't as smart as the other carbs, they have to wear protective helmuts and large soled shoes, and they ride the little school bus.....
Old 11-24-2011, 08:36 AM
65tripleblack
65tripleblack's Avatar
Congratulations, your hard work has paid off! 1.416 HP/cu-in is stout indeed. I don't know that the cast manifolds are hurting you, especially if you had them extrude honed by Brzizinski. The tri-power setup is killing you. Ever thought about "cloning" the L72 instead?
The very large intake ports hurt the bottom/midrange torque.........and it shows. Good for peak power number and pushes the peak RPM further up by a few hundred.
Now, if you can only "disguise" mechanical front/rear carbs, you'd lose that big dip around 3150.
Quick Reply: 542” Tri-Power motor, cast iron exh.manifolds – 671.05 rwhp through mufflers!
