Rear Spring
Rear Spring
I have been reading the posts related to the rear spring, and I have a question concerning which place to get one. My 64 is a stock 327/365 Vert and for the last 22 years I have had the fiberglass mono shock on the rear and put the monoshock setup on the front also. I would like to go back to the original standard 9 leaf spring and keep the front set up the way it is. Now for my question, I have heard a lot about eaton (i think thats the name) springs, but I have also heard Long island corvette has a spring that is the same as original except no logo and not show quality but ride height is suppose to be the same as original for $145.00. Has anyone bought one of these? I deal with Lic quite a bit but would like some of your expertise on this. Also what kind of rear shocks would be good for a decent ride without breaking the bank. Thanks in advance and there is nothing better than asking the ones that not only know but have already gone through this.
Jim
Jim
St. Jude Donor '05, '09, '15
I have a fiberglass rear spring so I can't answer directly. Eaton is mentioned on here allot as a good source for a rear spring. Do a search for "rear spring" or "Eaton" and I'm sure you will find your answer.
Tom
Tom
I am currently having my suspension including leaf spring replaced on my '65 365. The shop i am working with, who specializes in Corvette Restorations, said that Eaton springs sit too high, so he prefers the ones that are "Made in India" - from CC or Paragon I believe.
You might also get in touch with Eaton, they will restore your original spring as well. They don't just "re-arch" your old spring, they'll actually re-temper it as well assuming it's a suitable candidate for restoration. Cost should be in the neighborhood of purchasing one of their replacement springs I think, but you'd have to check.
