Identifying my trans
Old 02-01-2013, 10:25 PM
mcb55-210
mcb55-210's Avatar
Default Identifying my trans
My '62 has T-10 trans, and has 3:36 rear gears, which I verified when I went through the rear end last summer. How can I determine if I have a close ratio or wide ratio trans?
I was just reading some other threads pertaining to this subject, and became curious as to what my car has.
Thanks for your help!
Old 02-01-2013, 10:55 PM
Donny Brass
Support Corvetteforum!
Donny Brass's Avatar
C2 of Year Finalist (track prepared) 2019
2017 C2 of the Year Finalist
if it looks like this, it has the wrong input shaft
Old 02-01-2013, 10:57 PM
Donny Brass
seriously, it's hard to do with the trans in the car, but this RPM calculator might help
http://www.angelfire.com/fl/procrastination/rear.html
Old 02-02-2013, 12:07 AM
Procrastination Racing
Procrastination Racing's Avatar
When I put that page up back in 1996, I had no idea it would still be getting used almost 17 years later.
Old 02-02-2013, 08:09 AM
mcb55-210
mcb55-210's Avatar
Thank you. My car is still a couple of weeks out from picking up, but I did go check it out again yesterday...currently being sanded with 5000 grit-the black really shines. I brought the hard top home with me so I don't have to worry about picking it up when I bring the car home.....getting excited!!!! I liked the silver color-really seemed to show off the body lines. But I don't think I am going to be disappointed with it being black.
Until I have to wash it everytime I drive it!
Old 02-02-2013, 11:43 AM
OC-1
OC-1's Avatar
unmolested 62
250, 300 hsp wide ratio
340, 360 hsp close ratio
trans out one turn of the input shaft with trans in 1st gear makes the output shaft turn approx 2.2 times for CR and 2,5 times for WR
2:20 first CR
2;54 first WR
some formulas for rpm drop @ speed found in archives here or the 'oter site'
Old 02-02-2013, 02:41 PM
JohnZ
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
2:20 first CR
2;54 first WR
Actually, it's the other way around - 2.2 turns of the input shaft to get one turn of the output shaft is CR, 2.5 turns of the input shaft to get one turn of the output shaft is WR.
Old 02-02-2013, 06:05 PM
mcb55-210
mcb55-210's Avatar
Thanks for the formula-engine/trans currently in the car. I guess it really doesn't matter what it is...gonna drive it no matter WHAT it is! Just would be nice to know what it is.
I appreciate you all taking the time to reply. This forum has the greatest members!
To Identifying my trans
Quick Reply: Identifying my trans
