Corvette Forum
Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-01-2013, 11:34 AM   #1
1967STER
CF Senior Member
Default Remove Parking Light Assembly
What is the best way to disconnect the the black rubber connection going into the front fender pannel without causing any damage?
Should I try and pry it out or simply pull it out ?
I've never done this before and it seems like it's in there quite strongly thus I'm concerned about hurting the wiring harness connection at that end with the wrong technique.
Application 1966.
Thank you,
Rabvet
1967STER is offline   Reply With Quote
Old 02-01-2013, 11:49 AM   #2
66jack
CF Senior Member
66jack's Avatar
use a putty knife and run around the edges as best as you can to loosen and break seal of gunk that has built up....then just wiggle and pull out...
66jack is online now   Reply With Quote
Old 02-01-2013, 11:52 AM   #3
dkleather
CF Senior Member
dkleather's Avatar
The rubber connector fits into the hole like a grommet would. Grab both sides of the connector and pull it apart. I think you should be able to reach under the fender and inside at the same time if I remember correctly. If the wall connector comes out of the hole it should fit right back in. Dave
dkleather is offline   Reply With Quote
Old 02-01-2013, 11:53 AM   #4
Scott Marzahl
CF Senior Member
The grommet has a circumferential groove that sits in the hole of the inner fender. With the headlight plug removed just use your thumbs and roll that front edge inward to release plug groove from fender and push back. Rubber could be all hard and maybe low heat fro hair dryer might help.
Scott Marzahl is online now   Reply With Quote
Old 02-01-2013, 11:57 AM   #5
1967STER
CF Senior Member
That worked perfectly ----- Thank you !!
Reload this Page Remove Parking Light Assembly
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
