Side yoke ?
Old 01-31-2013, 03:47 PM
64Ragtop
64Ragtop's Avatar
Default Side yoke ?
I am in the process of replacing the diff in my 64 with a used 69, 3:70 model which didn't come with side yokes. Would it be advisable to replace the yokes at this time or use the ones out of my old diff? The 69 diff came out of a big block car and didn't have any noise or noticeable problems at time of removal. Thanks in advance.
Old 01-31-2013, 03:59 PM
toddalin
toddalin's Avatar
Received 1,167 Likes on 486 Posts
I would (and did) replace the small block yokes with the big block yokes.
Old 01-31-2013, 04:35 PM
claysmoker
claysmoker's Avatar
St. Jude Donor '09-'11-'12-'13-'14
Cheap insurance if you drive like I do.
Old 01-31-2013, 07:45 PM
DansYellow66
Support Corvetteforum!
DansYellow66's Avatar
Received 2,620 Likes on 1,952 Posts
You can exam them for excesive wear and test fit them for excessive in-out play. If OK, no harm in re-using them.
Old 01-31-2013, 08:50 PM
Hitch
Hitch's Avatar
I haven't broken a small block yoke .... yet..
Hitch
Old 02-01-2013, 10:21 AM
Dan Hampton
Dan Hampton's Avatar
Received 1,728 Likes on 810 Posts
2018 C1 of Year Finalist
Replace the yoke seals in the case, as well as your pinion seal, since you have the unit out. Cheap insurance down the road.
Old 02-01-2013, 10:30 AM
64Ragtop
64Ragtop's Avatar
Thanks to everyone for the good info. I already have the new seals in place and will check for end play at the yokes. I think it's .008 to .010. between yoke and pinion shaft. We also did a backlash test and the ring and pinion are meshing perfectly.
To Side yoke ?
Quick Reply: Side yoke ?
