Wiper Motor for Restomod group or non NCRS looking for better rain driving.
I am using a wiper motor that I purchased from Detroit Speed & Engineering. It was manufactured to be used on a 67 Camaro. The unit has 2 delays and 5 speeds. Installation only required very minor modifications to use this motor.
1.) I removed the existing motor backing plate from the firewall
2.) built a new motor backing plate from 18 gauge metal to accept the new motor
3.) compared the wiper motor arm on the new motor to the arm on the old motor. They were within 1/4 of an inch in rotating diameter and at the same protrusion through the firewall and they had a different end for the arm to attach. So it was a simple modification to combine the two rotating arms to make a new arm.
4.) To make the new arm, I simply cut off the end of the existing wiper arm from the DSE unit and then did the same to the arm from the wiper and then welded the end of the old unit to the end of the new unit.
My next mod will be to create better wipers as well. Most people will overlook the motor and wipers as they are used infrequently, but I live along the coast at the beach part of the year and heavy rain will pop up from time to time without notice so I want something that will clear the windows.
I will post pictures of the installed wiper motor next weekend when I have it completed if anyone is interested.
2019 Corvette of the Year Winner
St. Jude Donor '15
4.) To make the new arm, I simply cut off the cut off the end of the existing wiper arm from the DSE unit and then did the same to the arm from the wiper and then welded the end of the old unit to the end of the new unit.
I too would love to see pictures of your project, it sounds like it has much merit. For a different technique at rain removal years ago I started using Rain X on all my different modern and old cars windshields. I noticed I didn't need to use my wipers at all, even in the heaviest rain. The water just beads up and rolls or blows away. I don't use Rain X anymore, I just wax the windshield when I'm waxing the car and I get much the same results. Water removal has become a non-event now, even in my old cars that have vacuum operated windshield wipers. In most cases I just don't need the wipers and when I do, I find what the factory supplied is sufficient. It works for me, your results may vary.
Thomas
Thomas
Does the rainx help in misty fog? You know, like when you need to use an intermittent one stroke (lots of fun with a recalcitrant solid axle wiper).
Of course, then it won't shut off in park position if the windshield gets too dry.....
Oh yes, please add some pics! (thought solid axles were the only cars with wiper challenges)
Years ago I flew Boeing 727's out in the South Pacific and we would apply RainX on the aircraft windshields before departure if we knew our destination was likely to be expecting heavy rain at the estimated time of our arrival. It worked extremely well in that instance. That's when I started to use in on my cars with good results as well.
I didn't mean for us to get off topic here. 65LS6C4 has done an interesting, orginal project that I think we'd all like some follow up information on. Since we were on the general topic of rain removal I thought I'd add a bit different approach to the problem. My apologies if my comments were inappropriate on this post.
Thomas
Last edited by BB767; 01-30-2013 at 04:26 PM. Reason: Substitue water droplets for balls
