How do you remove a distributor and reinstall in same location
I would like to remove the distributor in my 62 and reinstall it to where it will go back in the same location. I know it can be done but I have never been able to do it. You would think if you pull it straight out, without disturbing the rotation. It would go back in the same location. I have never had any luck. Is it because the slot in the oil pump shaft will not line up again with the slot in the distributor main shaft..
I then lift the cap on the distributor and note the position of the rotor ie. Pointing to the clip on the rad hose etc.
Then extract the distributor. Now when you place it back in place you have to insert the distributor so the rotor is slightly counter clockwise to its final position because the gear on the bottom of the distributor is curved so that it engages the Cam gear. As it slides into place the rotor will move clockwise.
So I am assuming that you are trying to keep the rotor in the perfect spot, as you lower the rotor. If so, that won't work and thats why your oil pump drive hangs you up. So turn the rotor counterclockwise a bit and try again. You will note as you extract the distributor the rotor will move as it turns out of the Cam gear. So you need to do the opposite when setting it back in.
Marking the block and dist collar with a fine black permanent marker puts your distributor back in "at the correct timing as well"
Thats all there is to it.
That works as long as you do NOT disturb or crank the engine between removal and installation. If this happens you have to find TDC on the compression stroke set things up from there.
Yes, don;t play with belts on your engine either or decide to remove the harmonic balancer because your crank will move.
Its not rocket science by any stretch -- I just did it on my '67 Chevelle this weekend.
Just in case you get completely boogered up doing it; this article (complete with pictures) by the famous Lars walks you through reinstallation.
That is a proper response, HE/SHE wants to do it, that's how its done. He/she said "I would like too...." as in he/she, himself/herself.
What I do, is while the distributor is locked down, I take a black marker and mark the collar on the distributor and the block with a fine black marker.
all you have to do is install the dist with the rotor turned at the same spot it rested after you pulled it and it will automatically mesh with the pump shaft and turn it with it and the dist. will seat....works every time...good luck.....
Dr. Detroit
Received 3,895 Likes
Just mark the base of the dist...along with the manifold....
Jebby
simple...as you pull the dist., the rotor will turn along with the pump shaft
Got dist removed and reinstalled, no problem
Got the dist removed, did what i wanted to do and reinstalled dist without any problems or retiming. I do not know what I was doing it in the past, which never worked, but using you guys help, it went right in, thanks
Good deal. For some reason this is one of the more intimidating jobs for many folks and it shouldn't be if you are careful and methodical.
