Changing Interior Color 65 Coupe
Old 01-22-2013, 12:56 AM
Janbery
5th Gear
Janbery's Avatar
Default Changing Interior Color 65 Coupe
The car is currently black on black and the interior needs an upgrade; seat covers, door panels, carpet, etc. and I want to change the color to red. I've looked at dozens of photos of 65's and there seems to be discrepancies as to what items are actually black regardless of interior color, and those that need to be red to be factory correct. Some photos show the steering column black on a red interior, and others red. Does anyone have a definitive list of the parts that would have to be replaced or repainted to make it correct? Is the headliner the same for all interior colors? The obvious items are:
o Seat Covers
o Seat Backs
o Carpet
o Door Panels
o Dash Pads (Left and Right)
o Dash Pad Door Jam
o Quarter Trim Panels
o Center Arm Rest Cover
o Left and Right Rear Window Moldings
o Left and Right Side Headliner Moldings
o Left and Right Door Kick Panel Trim
o Shift Console
o Seat Belts
I'm sure I'm missing some items but can't find a source to identify them all. Any suggestions would be appreciated!
Janbery
Old 01-22-2013, 06:54 AM
Phil Zell
Phil Zell's Avatar
You will probably be better off posting this in the C-2 section of the Forum
Old 01-22-2013, 10:20 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,468 Likes on 1,247 Posts
Cruise-In II Veteran
What's the interior color code on your trim tag? The NCRS Judging Guide, the assembly instruction manual (AIM), Noland Adams' Restoration Guide Volume II, and Dr. M. H. Dobbins' book would all be of help to you.
Old 01-22-2013, 03:55 PM
65GGvert
65GGvert's Avatar
Received 3,217 Likes on 2,301 Posts
o Seat Covers
o Seat Backs
o Carpet
o Door Panels
o Shift Console
o Seat Belts
o Dash center
o Sun visors
o Headliner
o Steering column black
o Dash Pad Door Jam (if you're talking about the "wings" that rivet to the jamb)= black
Janbery
Above applies IF the interior is red and the exterior black.
To Changing Interior Color 65 Coupe
Quick Reply: Changing Interior Color 65 Coupe
