Removing 67 dash
Removing 67 dash
Currently have the center console, stiring column, instrument cluster, and glove box removed...can't figure out how the dash comes out. I have yet to look at the manual but if someone out there can give me a quick explanation it would be much appreciated.
Dave
Dave
Did you drill the rivets out on each side, if I remember I think there are 5 on each side. Also under the dash there are a few nuts that need removed. Use the AIM you wont have any problems. If you need pictures I probabaly have some. Does your car have AC? if so you need to remove all that ducting. Good luck
Also the center dash section is bonded to the top of the transmission tunnel. A putty knife can separate it with a rap from a hammer.
Received 1,856 Likes
Do you have the Assembly Manual? It's all shown in detail in UPC 1-Bolt/Weld, sheet A9; five pop rivets at each end, ten bolts across the top, and a blob of bond at the bottom center.
