'66 - What are all these capacitors for (pic)?
I pulled the instrument cluster in my '66 to fix the speedo. There are 3 capacitors behind the cluster. In the picture below, #1 was connected to the battery gauge, #2 is the radio capacitor and #3, above the temp gauge was disconnected (with a tag on it saying "spliced"). In addition, there is another capacitor connected to both terminals of the brake light switch.
What are all these for and does it make a difference if #3 on the pic remains disconnected? If it should be connected, where does it go? The electrical diagrams do not show any capacitors.
Thanks so much!
Thanks so much!
Radio noise suppression.
Here ya go...
I just went through this with my car...
http://www.lbfun.com/warehouse/tech_...ess-Labled.jpg
All of that just to eliminate radio noise (along with the shields over the spark plug wires). Imagine that. Since my radio sounded real good before I took this apart, I guess I can just leave that one capacitor disconnected.
Thanks for the quick responses.
How often will that scenario happen?
The one under the OIL gauge plugs into a dark brown wire that is always hot. If you choose not to connect it, make sure the dark brown wire doesn't get accidentally connected to the ground tab above the Tach (which can happen).
Received 1,858 Likes
As Jeff said AM (Amplitude Modulation) radio was horribly susceptible to interference and static whereas FM (Frequency Modulation) radio is less so. But AM is all they had back then and capacitors were cheap but have a limited life span.
Your originals are probably long since shot to hell. So you can leave them in or take them off - no difference.
