66 SB hard to start when sitting for a month or so...any ideas why
After the car has been sitting for a month or so I have to pump the gas peddle 20 to 30 times to get it to start. Runs fine once it is started. From then on starts right up hot or cold.
1) Carburetor bowls are not empty as I can see gas being squirted into the carb if I manually move the linkage back and forth (before I pump the gas peddle 20 to 30 times).
2) Choke plate closes after initial gas peddle pump
3) Carb has been rebuilt
4) Fuel pump replaced
5) Pertronix electronic ignition with new coil
6) Engine burns a little oil but nothing signifcant but there is an oily residue on the spark plugs
7) Spark plugs and wires replaced. Problem continues.
Any ideas?
Could the oil residue on the spark plugs prevent car from starting until gas "washes" them clean?
I'm stumped. Thanks in advance for any suggestions.
Ron
Any ideas?
Ron
Any ideas?
Ron
Any ideas?
Ron
if indeed the choke is working properly, i would check for fire, in fact why don't you check for fire first the next time this happens.....good luck
if everything you state is correct, and i assume it is, i would set the choke plate a little richer. it should slam shut and stay there until she fires when the pulloff comes in to play.
Received 1,843 Likes
I'll take your word for it the carb is shooting "something" when you first pump the gas. I'll also bet what it's shooting won't fire in the cylinder.
Next time you let the car sit for a month, drop a tablespoon full of fresh gas down the primary throat of the carb and see if it doesn't kick right off.
St. Jude Donor '14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
You can dribble gas into the carb by pouring it on top of air cleaner stud/screw, it will save having to remove lid. Plus minimize any backfires ....
Received 1,857 Likes
When mine sits that long, I use a plastic ketchup dispenser bottle - the nozzle is just right for fitting into the bowl vent tube; about 1/3 of a bottle fills the float bowl, and it fires right up without all the cranking.
John
your wife is OK with using the bottle for that? Maybe that occasional 1/3 fill with gas adds a little kick to the ketchup?
I've tried bottles like that and the gas usually eats through them so I bought one from Jeg's that seems impervious to fuel..
This elderly woman then says to me "So nice to see a man who likes to cook" , I didn't have the heart to tell her.
Paul
If a shot of fresh gas makes your engine fire right off, I think you could make the assumption that you just need to fill the fuel bowl with fresh gas from the fuel pump.
I never did see any sense in raising the hood, taking the air cleaner lif off, squirting gas in the carb and getting your hands all stinky and then putting everything back together, washing your hands and the starting the car.
It's much simpler to just crank the engine for about 5-6 seconds, stop cranking and fan the gas a few times and then crank it again and it starts/runs.
Besides, everytime you pull that hood release, you're just one pull closer to having the cable break and then you'll be on your back trying to trip the hood latches with a broom stick.
I do the same thing. Works great on Holleys. I found JEGs even sells a plastic priming bottle specifically for this.
on my 61 i have a prime button under the dash(for the electric fuel pump). turn key on, press for 2 sec, turn to start, pump twice, instantly starts.
so if 2 weeks go by, and i don't drive it, i just prime it to keep fresh gas in the carb. otherwise it might, on rare ocasion, dry out and leave flakes in the carb. and clog it.
