half shaft caps and bolts
Old 06-25-2013, 12:17 PM
mrg
mrg's Avatar
Default half shaft caps and bolts
The later diff carrier units that use caps and bolts, instead of u bolts and nuts: The center line hole in the caps being offset to one side, does the offset go in (towards u joint) or out (away)? .. The caps also have and arrow embossed into them for orientation - again not sure if that means 'in' or 'out'. ..
I thought the diff change out was going to be a straight across bolt-in............NOPE! . .
Old 06-25-2013, 07:52 PM
DansYellow66
Support Corvetteforum!
DansYellow66's Avatar
Received 2,620 Likes on 1,952 Posts
I don't think I noticed this on mine but I may have just oriented them in the manner in which they aligned with the yoke seat and forgot about it. In any event this will bump this back to the top for further input.
Old 06-26-2013, 11:52 AM
tracdogg2
tracdogg2's Avatar
Factory caps are not offset. Aftermarket ones are because they are not made correctly. New OEM style are available.
Mike
Old 06-26-2013, 12:42 PM
redvetracr
redvetracr's Avatar
I have some extra genuine GM caps if you or anyone else is interested...
Old 06-26-2013, 01:38 PM
mrg
mrg's Avatar
Dan ..
Thanks for the bump. This thing with the offset caps, I have to wonder why they were done or made that way. I did install them on one stub axle to see how they looked. It seems the offset portion is supposed to install 'in' (towards u joint). One thing I noticed is that the offset portion does seem to capture more of the u joint trunnion. Maybe that was the reason for making these particular caps that way? ..
tracdogg2 ..
Well, now I'm wondering about that. The other thing I noticed is that after tightening down these offset caps, there appears to be a slight in the center split between mating ends. Appears to be about an .008 thou gap, or so. I can see partial thread of the bolts.
redvetracr ..
I'm interested in those caps. The last thing I need is to have a situation where some kind of cap crap out occurs hundreds of miles from home.
Old 06-26-2013, 01:47 PM
tracdogg2
tracdogg2's Avatar
Buy the correct caps from Redvetracr. There is supposed to be a slight gap between the cap and the axle.
Mike
To half shaft caps and bolts
Quick Reply: half shaft caps and bolts
