Corvette Forum
Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-13-2012, 01:44 PM   #1
rick piras
Junior Member
Default S&P now has shorty headers for LS motors w/mechanical clutch linkage
I know most of the guys running LS motors are using hydraulic clutch setups, but for simplicity I wanted to use the stock mechanical setup with the Z-bar. I worked long distance with Street & Performance by having them send me tack welded headers that I was able to modify, tack weld the primaries in better locations, and then they designed a jig to match. After a few attempts, they now have something that should clear the stock linkage, as well as the stock steering box very nicely. I worked with Gary in their header department, and if you're planning to go this route, I'd suggest you ask Gary to send you a set in the tack welded version to fit check and be sure it'll work for you, and then return them for final welding and ceramic coating.
I'd seen some inquiries from guys asking if there was such an option available, now there is.
Regards,
Rick
rick piras is offline   Reply With Quote
Old 12-14-2012, 01:22 AM   #2
00fxd
CF Senior Member
00fxd's Avatar
Need some one to make Hooker style sidepipe headers for stock driveshaft length engine placement ... Don't know why one would use Hyd clutch actuation with the high quality Scoggins Dickey LS Clutch cross shaft bracket readily available ...
00fxd is offline   Reply With Quote
Reload this Page S&P now has shorty headers for LS motors w/mechanical clutch linkage
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
