Corvette Forum
Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-12-2012, 09:11 PM   #1
claysmoker
CF Senior Member
St. Jude Donor '09-'11-'12-'13
claysmoker's Avatar
Default Weird noise
Just finished the new engine for the '64. No it didn't need it, but I like building engines and wanted one just for this altitude (5000') and with more torque and compression just for up here.
Specs:
Dart SHP block, 4.155" bore, 3.75" stroke.
Callies crank and rods.
Mahle pistons, 11.6 to1 with 64cc chambers AFR 195cc heads.
Howard hydraulic roller cam with 272/278 duration, .530" lift.
Comp 1.5 roller rockers.
Compression checks 195 to 200 in all cylinders. Oil pressure 50+ psi and steady.
The engine is running on a test stand and the noise is loudest from the bellhousing area(flywheel installed, but no clutch). Laying the stethescope on the base of the distributor produces the loudest noise, and follows the rpm as it comes up. It sounds just like a loose rocker, but it is not.
I've talked to techs from both Dart and Howards and both thought oil pump and or distributor were the source of the noise, so I pulled it apart and replaced both parts with new pieces. No change. While the pan was off I pulled all the main and rods caps and everything looks dandy.
I'm about out of ideas at this point never having had an engine do this before, so I'm looking for thoughts, positive, negative or otherwise.
Any help appreciated.
Dave
claysmoker is online now   Reply With Quote
Old 12-12-2012, 09:16 PM   #2
Sky65
CF Senior Member
St. Jude Donor '05-'09
Support Corvetteforum!
Sky65's Avatar
Can you pin down the frequency? Crank speed, cam speed or erratic?
Tom
Sky65 is offline   Reply With Quote
Old 12-12-2012, 09:30 PM   #3
claysmoker
CF Senior Member
claysmoker's Avatar
Cam speed. It follows the throttle exactly and sounds like a loose rocker. If I stick the steth probe on the distributor it sounds like a nasty knocking noise.
Gotta take the dog to obedience class now, back in a couple hours.
Old 12-12-2012, 09:33 PM   #4
67vetteal
CF Senior Member
67vetteal's Avatar
Are you using the mechanical fuel pump? They have been known to "Tick" like a rocker.
67vetteal is offline   Reply With Quote
Old 12-12-2012, 09:40 PM   #5
Sky65
CF Senior Member
Sky65's Avatar
Are you using a cam button or retainer plate? Retro roller cam/lifters or stock GM style?
Old 12-12-2012, 10:20 PM   #6
midyearvette
CF Senior Member
midyearvette's Avatar
be sure the dist. is not bottoming out on the pump shaft....pull the dist and set it back in without the round gasket, it should fit snugly atop the intake manifold....any gap is bad news, maybe need two gaskets or a nylon shim??......just thought i would take a shot...good luck....
midyearvette is online now   Reply With Quote
Old 12-12-2012, 10:33 PM   #7
cuisinartvette
CF Senior Member
St. Jude Donor '05
Same issue did it as a new 350 and right off the bat when I stroked it.
Thought maybe the endplay was loose or a lifter touching another lobe.
Cant pinpoint it everything checks out just running it anyway.
Done/checked everything else known to man lol.
cuisinartvette is offline   Reply With Quote
Old 12-12-2012, 11:30 PM   #8
claysmoker
CF Senior Member
claysmoker's Avatar
Quote:
Yes, but it's quiet at the front and all around the pump.
Old 12-12-2012, 11:38 PM   #9
claysmoker
CF Senior Member
claysmoker's Avatar
Quote:
There's a thrust plate behind the cam gear and a roller button against the timing cover. All Cloyes parts and set up with their recommended .003" to .005" end play.
It's almost like there is something out of line in the distributor shaft/pump drive shaft/pump. I'm using a ARP drive shaft which is constant OD and I've noticed that some shafts have a reduced diameter through the mid part. I saw no evidence that the shaft was hammering inside the clearance hole, but I may swap shafts since I'm probably tearing it apart again anyway. There's no big rush to get it in the car since I wasn't going to put it in until next Spring anyway, but I have to find out what's doing it. Not being correct just drives me nuts.
Old 12-12-2012, 11:44 PM   #10
claysmoker
CF Senior Member
claysmoker's Avatar
Quote:
Yes, checked that during assembly and the distributor easily goes in all the way to the bottom of the collar without a gasket. If it comes down to experimenting I can make an adjustable collar and turn the shaft to accept it. Pretty easy actually but I hope I don't have to. I actually loosened the clamp slowly while it was running and as I suspected it started to lift the distributor with no change in the knocking noise. I let it come up about .060" or so before I pushed it back down. Just an experiment.
Old 12-12-2012, 11:46 PM   #11
claysmoker
CF Senior Member
claysmoker's Avatar
Thanks for the comments. I'll keep digging.
Old 12-13-2012, 02:09 AM   #12
EDinPA
CF Senior Member
EDinPA's Avatar
I'm building an engine now and also using a roller cam, although it is from Comp Cams. They require a composite distributor gear for use with the retrofit roller cams. A quick look shows that Howard offers one as well. Perhaps the same exact part. Did they mention if one is needed for their cam?
EDinPA is offline   Reply With Quote
Old 12-13-2012, 02:17 AM   #13
Westlotorn
CF Senior Member
Westlotorn's Avatar
Sounds like a challenge to find. A distributor noise should sound off at 1/2 engine speed . The cam rotates at half crankshaft speed.
I have seen a odd noise like this cause by Flywheel mounting bolts, one was just long enough to hit on the back of the block on each rotation. Made one heck of a noise and was hard to determine.
A cracked flex plate can make this noise also but I think I read you have a flywheel on this engine.
How much piston to cyl head clearance do you have? Any chance you have one tapping on the cyl head? Sounds like a minor rod knock when you have this issue.
I may be off base but trying to kick out a couple new possibilities.
Westlotorn is online now   Reply With Quote
Old 12-13-2012, 02:20 AM   #14
Westlotorn
CF Senior Member
Westlotorn's Avatar
This engine is stroked, any chance the Connecting rods are tapping the block or a piston skirt. This was an issue when 383's GM engines were first being created. ARP offers Rod Bolts that offer more clearance and many have had to grind on blocks for clearance.
Old 12-13-2012, 04:44 AM   #15
65 vette dude
CF Senior Member
65 vette dude's Avatar
Is the flywheel cover installed?
65 vette dude is offline   Reply With Quote
Old 12-13-2012, 10:57 AM   #16
claysmoker
CF Senior Member
claysmoker's Avatar
Quote:
You are likely using a solid roller, correct? For hydraulic roller cams it's not required, but as easy as it is to try one, I'm tempted. What could it hurt? Whole bunch easier than tearing down the engine again.
Old 12-13-2012, 11:02 AM   #17
claysmoker
CF Senior Member
claysmoker's Avatar
Thought about the flywheel but I checked the bolt clearance so that's out. Checked for being loose too but no go.
Piston to head is .043", and I put the scope probe on the heads at each cylinder. All quiet. Also tried pulling one plug wire at a time, no change.
Thanks for the thoughts.
Old 12-13-2012, 11:05 AM   #18
claysmoker
CF Senior Member
claysmoker's Avatar
Checked during assembly. This block can go to a 4" stroke without interference. The only clearance issue could have been rod to cam, but I don't have near enough cam to make that happen.
Old 12-13-2012, 11:06 AM   #19
claysmoker
CF Senior Member
claysmoker's Avatar
Quote:
Nope. And the flywheel isn't hitting the bellhousing either.
Old 12-13-2012, 11:10 AM   #20
AZDoug
CF Senior Member
AZDoug's Avatar
FWIW, my 3.85" stroke 427 SB needed a special cam with a smaller base circle AND cam clearanced rods and rod bolts so the cam and rods would not touch each other.
You have only .050" less radial distance than my crank, my cam has a .050" smaller base circle. And it isn't a radical cam
This was on a std deck height Dart Little M
Doug
AZDoug is offline   Reply With Quote
Reload this Page Weird noise
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
