Corvette Forum
Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-12-2012, 03:43 PM   #1
Chef_65vert
Junior Member
Default 65 VIN and other # help
So, I crawled around and in my car and have a question or two. What cM be learned from the VIN? 194675S1088x also took some from the trans, bellhousing, and rear end. Please help me decode them as I'm trying to figure out if the trans and rear are original to the car. Passenger side front of the trans has 3851325, rear of trans has 3857534 there is a circle with a 5 inside near the front numbers. The bellhousing has 3858403. The rear end has 3871375.. and a small tag on the drivers side of the trans under a bolt has 3857579. Any help or input will be greatly appreciated.. gonna try to get some pics up tonight!
Chef_65vert is offline   Reply With Quote
Old 12-12-2012, 04:16 PM   #2
65GGvert
CF Senior Member
65GGvert's Avatar
Send a message via AIM to 65GGvert
All you can tell from the partial vin you provided is that it's a 65 convertible and was made sometime around Feb or Mar. The transmission should have 51088xx (vin) stamped on it if it's original to the car. The rear doesn't have a vin, but should have a two letter code followed by a date on the bottom edge just above the spring. (example AM 3 15 65)3:36 made Mar 15 65. Not much way to tell if the rear is original except by date assembled. If you post pictures, post the trim tag too. That will help with dates. Is it possible the number on the rear section is 3857584? The transmission should also have a date code stamped like for example P0315 or the like along the edge.
65GGvert is offline   Reply With Quote
Old 12-12-2012, 04:24 PM   #3
Vet65te
CF Senior Member
Vet65te's Avatar
The stamped code(s) on the differential can be seen by looking straight up when under the car between the spring bundle and the strut bar bracket. This is a pic from my 65 but it's actually a 3:08 posi from a '68 Vette.
Click the image to open in full size.
Mike T.
Vet65te is offline   Reply With Quote
Old 12-12-2012, 04:44 PM   #4
65GGvert
CF Senior Member
65GGvert's Avatar
Here's a pic of the axle date on a prior 66 I owned.
Old 12-12-2012, 04:59 PM   #5
1snake
CF Senior Member
1snake's Avatar
Quote:
Your VIN is missing a digit but in addition to the above info., Your trans is a close ratio Muncie (according to the metal tag) and it's correct for a Corvette. The number on the rear trans. housing should read 3857584. Your bellhousing is correct for your car. The rear has the correct casting number but the stamping will tell exactly what it is.
Jim
1snake is offline   Reply With Quote
Old 12-12-2012, 05:11 PM   #6
Chef_65vert
Junior Member
The last # of my VIN is an 8. The # on the rear trans housing could very well be an 8 rather than 3 as I was on my back using the flashlight on my phone! I didn't know where to look for the stamping on either the trans or the rear. I'll try to get a pic up of the trim tag.
Old 12-12-2012, 05:17 PM   #7
1snake
CF Senior Member
1snake's Avatar
I meant your VIN is short 1 number. It should read 194675S1xxxxx, the last 5 being the number of the car somewhere between 00001 -23564.
Jim
Old 12-12-2012, 05:41 PM   #8
Chef_65vert
Junior Member
Sorry.. it is 10888
Old 12-12-2012, 05:41 PM   #9
Chef_65vert
Junior Member
I'll post pics in a while. I can't copy and paste from my Android
Old 12-12-2012, 06:38 PM   #10
65GGvert
CF Senior Member
65GGvert's Avatar
Sorry.. it is 10888
You're still a digit short. It's S108 plus three more digits. Example: Mine is S106778
(Unless it's S100888, S110888)
Old 12-12-2012, 06:48 PM   #11
Chef_65vert
Junior Member
Wow, I did leave a 1 out in my original post and in my reply.. yes, it is 110888
Old 12-12-2012, 06:55 PM   #12
65GGvert
CF Senior Member
65GGvert's Avatar
OK, so Feb 65 build
Old 12-12-2012, 06:59 PM   #13
Chef_65vert
Junior Member
Home now. Gimme 10 and ill link pics of the car, trim and vin tags
Old 12-12-2012, 07:41 PM   #14
Chef_65vert
Junior Member
Old 12-12-2012, 07:52 PM   #15
Chef_65vert
Junior Member
Old 12-12-2012, 07:56 PM   #16
Chef_65vert
Junior Member
Old 12-12-2012, 07:57 PM   #17
65GGvert
CF Senior Member
65GGvert's Avatar
St Louis body, built Feb 24th, red w/black vinyl interior
Old 12-12-2012, 08:00 PM   #18
Chef_65vert
Junior Member
Old 12-12-2012, 08:01 PM   #19
Chef_65vert
Junior Member
Old 12-12-2012, 08:02 PM   #20
Chef_65vert
Junior Member
Reload this Page 65 VIN and other # help
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
