Corvette Forum
Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-23-2012, 10:40 AM   #1
Roger Kendall
Junior Member
Default Radio operation for a 1957
Should the radio operate with the key in the off position?
Roger Kendall is offline   Reply With Quote
Old 11-23-2012, 05:06 PM   #2
JohnZ
CF Senior Member
Support Corvetteforum!
Quote:
Nope. The key must be on for the radio to operate.
JohnZ is offline   Reply With Quote
Old 11-26-2012, 05:51 PM   #3
Roger Kendall
Junior Member
Please give me source of your reply.
Is this in the owners manual or perhaps in NCRS judging manual ?
I would like to be sure the ignition key must be on for the radio to work before I try to change any under dash wiring and yours is the only reply I received.
Old 11-26-2012, 06:14 PM   #4
rich5962
CF Senior Member
rich5962's Avatar
Roger,
John is positively correct. The radio is powered only when the key is on, and is a fused circuit sourced from the pink wire coming from the ignition switch. This pink wire has no power when the key is in the off position. Another pink wire powers the directionals via the flasher, which should also only be powered with the key to on.
I would suspect that a prior owner rewired the radio to constant power so it could work with ignition off. This would save the distributor contact points from burning up(if closed), while the radio was playing.
Rich
rich5962 is offline   Reply With Quote
Old 11-27-2012, 02:27 PM   #5
JohnZ
CF Senior Member
From the NCRS P.V. (Performance Verification) Judging Manual, and from the Assembly Manual, section F.O.A. 102, sheet 2.00, View "A" - that buss on the junction block where you install the radio fuse is fed from the ignition switch.
Reload this Page Radio operation for a 1957
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
