You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
It's a beautiful day here in Southern Ontario! About 60 degrees.
I took my '63 convert out for a country spin this afternoon.
It's been going on since I bought the car but never got around to asking the Forum about the shifter that kind of rattles when under a load. It's not bothersome to anyone but me.
It's a 327/300. I assume it's a muncie but I haven't been under the car to check. It shifts perfectly fine, clutch engagement is excellent and runs like a dream.
Any idea what makes the shifter rattle? If I lay my hand on it, it becomes quieter.
They all seem to rattle, it's very common. If you look at old posts you'll see what I mean. I and many others have tried to cure it but the only cure seems to be a Hurst shifter conversion. I'm adopting the old "if it aint broke don't fix it" attitude. Gary
Thanks Gary. I guess I should have done a search first.
Good know there is a fix in the Hurst conversion.
Quote:
Seems the transmission mounted Muncie shifters suffer this the worst. My '64 had a bad problem with this at freeway speed. A new rear housing bushing and slip yoke, and having the drive shaft and half shafts rebalanced made most of the vibration problem go away. A bit of shifter buzz/rattle is still there, but comes in at higher (than before) freeway speeds.
Location: The Great White North. Mellowing with age like fine wine!
I just kinda chuckle every time a noob posts this topic. Been there done that, got the Hurst! I used to wrap a towel around my 66 to hush it up. It's even worse on short throw. I rebuilt mine and it still did it before I retired it. Some people here have dealt with it but I suspect they use the long throw position with rebuilding. Have fun.....from Ottawa.
Location: Livin' large and havin' fun in wonderful Oklahoma
You don't state whether shifter is original or aftermarket. Original '63 shifter had a spring on the lower part of the lever. If spring is missing shifter will buzz some.
As I recall, there was a factory correction for this that was documented in a GM Service Bulletin for '63 shifters. Seems the solution is to cut up some of the nylon window-crank spacers,creating small "C-shaped" washers that can be slipped behind some of the shifter pivot shafts to take up the slack.
Sorry for the rough description here - but if you search around on this or other Corvette websites - I'm sure you'll find the Service Bulletin posted by someone. The fix is clearly illustrated.
I rebuilt the Muncie shifter on my '66 with the rebuild kit that is available from most of the vendors (along with John Z's tech article from a few years back) and it's great. Plus, I love that clunk-clunk feel of the Muncie shifter.
I thought I would give an update on the rattling shifter. ....
I bought a new rubber O ring as someone suggested. I unscrewed the **** and installed the O ring. Although it still rattles slightly, it's noticeably better! Thanks for the help.
