which wiring harness should I buy?
I ......
I need to ....ne without aircon?
Last edited by alexandervdr; 11-11-2012 at 10:30 AM. Reason: got posted twice, don't know how to delete a thread...
Call the manufacturer of the airconditioning system you plan to install. I have to believe they design their systems on the basis that the car in which it will be installed, does NOT have the A/C wiring harness.
I did ask Vintage Air directly, and here is the answer. (very fast, within a day!)
"The one w/o AC would be fine - the Vintage Air system comes with its own
wiring harness that will connect the power and ground directly to the
battery and one "key on" wire that will go to your fuse block or ignition
switch.
Vintage Air"
switch.
Vintage Air"
If that is correct, it depends on where the alternator is mounted. If I am correct, if AC equiped (VintageAIr and others) this is on the DriverSide, so harness to use is the one for aircon.
Prior to installing the new wiring harness my Alt was located on the D/S. When I ordered the harness I just ordered the one listed as "except A/C". I had to relocate the Alt to the P/S to connect the wiring. Not a big deal.
