1960 vin tag locations
Paid Senior Member
For all 1960 Corvettes, the location of the Vehicle Identification Number (VIN) is located on the steering column in the engine compartment.
The 1960 Corvette is the first year that did not feature the VIN tag in the door jamb (as with all previous models).
Received 6,521 Likes
C2 of Year Finalist (track prepared) 2019
Similarly, early '60 engines did not have a VIN derivative stamped on the engine pads; later engines did.
Jim
Regards, John McGraw
Paid Senior Member
See where members are moving tags from steering column to doors.
http://forums.corvetteforum.com/c1-a...or-1960-a.html
Read 1960 description.
http://www.corvsport.com/Corvette/C1..._1960_VIN.html
If you find a 1960 with the VIN on door jamb, run...
Paid Senior Member
Per Noland Adams "C1 Restoration & Technical Guide" -- "Relocation of the serial number plate from the door post to the steering column occurred on AIM date 11-24-59 about the time car number 00867S101400 was being assembled."
This has been widely known for decades.
Fullcontrol, I assume you don't have a 1960 Assembly Instruction Manual. Section 14, Page 1 makes reference to the old part number of the VIN tag and the next line makes reference to the relocation.
Someone has provided you with incorrect information somewhere along the way. Original 1960 cars and the 1960 AIM don't support your claim.
Paid Senior Member
Just seeing how ruffled you old timers get...
But seriously, take Noland's advice and be sure to stick a copy of this in your glove compartment just so you have something to read as your car is being towed down the highway.
http://www.earlycorvettes.com/corvet...msvinplate.pdf
Paid Senior Member
I have owned 2 early 60 cars, and the both had door pillar tags, and both cars were unmolested. One went on to win a Duntov award. Check the NCRS judging guide, Nolan's book, and many other sources. Tag did not move to the steering column until about mid-December
So what is the proper process for cars with replacement front ends and new modern steering columns? I have an IDIDIT column due to my Meyers conversion and with the column support brace in place there is not enough room to put it back on the column.
Paid Senior Member
I know of a local restoration shop that was indicted for having the steering column out of a car they were working on.
Paid Senior Member
Lesson learned... don't touch the VIN tag. According to the State, once the steering column is pulled the car becomes a pile of parts. The caveat of course is the day of the week and the officers involved, your results may vary.
It was all subjective with serious consequences.
I have a bracket that is outside the firewall on the column, did you find a bracket to put inside the firewall? I guess I could look for one that goes inside, it looks like the one from Corvette Central works that way so I may try that.
