T-10 trans decode help needed
Old 10-04-2012, 01:10 AM
sschevellefan
Cruising
sschevellefan's Avatar
Default T-10 trans decode help needed
This transmission came in my 65 el camino but I dont know anything about it other than its been rebuilt and upgraded a bit. I know the original 16 spline output shaft was replaced with a 27 spline output shaft along with a complete rebuild. Here are the only numbers Ive found on it,
Main case- T10-1C 3782212
Tailshaft- T10 7D 3813490 / Has R-1 on a small tag
Side cover-8-10-62A
Bellhousing- 3858403
The input shaft has no splines and I was told that means its a close ratio with a 2.20 first gear. Im just trying to figure out what it is that I have. Any help would be great.
Old 10-04-2012, 04:00 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
Side cover-8-10-62A
The main case was used on '61-'62 Corvettes and 409 passenger cars.
The tailhousing was used on '62-'63 Corvettes and passenger cars.
Put it in 1st gear and see how many turns of the input shaft it takes to turn the output shaft one full turn; if it's 2-1/4, it's a close-ratio 2.20 low gear - if it's 2-1/2, it's a wide-ratio.
Old 10-04-2012, 05:08 PM
DZAUTO
DZAUTO's Avatar
Received 3,772 Likes on 1,674 Posts
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
I think you mean the input shaft has no rings (or grooves) around it, instead of no splines.
Tom Parsons
Old 10-04-2012, 10:12 PM
sschevellefan
Cruising
Tom Parsons
Yep your right Tom, I did mean rings, not splines.
Old 10-04-2012, 10:26 PM
62corvette
62corvette's Avatar
8-10-62 is August 10, 1962. Early 63 model year.
Old 10-04-2012, 10:40 PM
sschevellefan
Cruising
Thanks guys. Im probably going to list it for sale but I wanted to know what it was that I was selling.
Old 06-07-2018, 05:17 PM
825 Vette
8th Gear
825 Vette's Avatar
Im seeing T10-1C transmissions with either a T10-7B, or a T-10-7D tail shaft housing. I know the 7-B housing is about 5/8" longer that the 7-D, but don't know which is correct for my Jan 62 Vette.
Where can I find Borg Warner T10 decode information?
Old 06-08-2018, 08:52 AM
desertpilgrim
desertpilgrim's Avatar
On the driver's side rear of the main case, you might find a stamping that begins with "W" and ends with "1", "2" or "3"; the "W" stands for
Warner Gear" and the numbers indicate which shift assembled the trans; If there's nothing, you've got one built from parts.
Old 06-08-2018, 03:36 PM
825 Vette
8th Gear
825 Vette's Avatar
Default Tail Shaft Decode
Im trying to find answers to 2 questions;
1) Which tail shaft housing is correct for a 62 Corvette? The T10 7-B or the T10 7-D?
2) If one of these tail shaft housings is correct for my 62, what would the other be correct for?
Old 06-08-2018, 09:06 PM
JohnZ
JohnZ's Avatar
Answered here:
https://www.corvetteforum.com/forums...plication.html
To T-10 trans decode help needed
Quick Reply: T-10 trans decode help needed
