Z28 Intake on a 1966 L79
C2 of Year Finalist (performance mods) 2019
Will the 1969 Z28 intake (3932472) fit under the small block hood? I have an all stock 1966 L79 and am considering changing the intake for a few more hp. Also, is it worth the trouble to change with a stock L79.
I have a half inch now between the air cleaner and the hood. Thanks for any help.
Mark
Mark
Received 6,978 Likes
2015 C2 of Year Finalist
I think the L79 intake is the same as a LT1/Z28 intake only with no oil fill tube
Mark
Mark
It's 5/8" taller.
They both have oil fill tubes too, GM LT-1, Z28 replacement intake. The thermostat housing bolt pattern is different and you may have to change housings so the hose lines up. This also required me to bend up a new fuel line.
Received 3,773 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
The early (the GOOD ones!!!!!!!) Z28/LT1 intake manifolds are/were the tallest FACTORY SB alum intake ever available. And as far as I'm concerned, this is/was the ultimate all around 4bl intake that Chevy ever came up with. I have one of these on almost all of my SB cars (of course, the 56 Vette has FI).
There were fundamentally TWO variations of this manifold (actually 3, but the third one is the same as the second version, but without a hole up front for the oil fill tube).
There was the 67-68 version (which of course was Z28 only) and the 69-72 version. The 70-72 version (I guess you could call it the third version) did not have a hole for an oil fill tube, BUT, it still had the boss, thus there was a place for the hole to be machined easily.
EXCEPT FOR CORVETTES AND TRUCKS, the alternator and air cond compressor swapped sides in 69. As a result, all SB intake manifolds (again, except Vettes and trucks) had some changes made to the front of the manifold.
Here is a comparrison between the 2 main versions (67-68 and 69-72). The intake with the adapter plate for a Q-jet is the 67-68 version (it is on a 350 in my son's 68 Chevelle). The most noticeable difference(s) is the water cross over passage, thermostat housing position, threaded holes for temp sender and heater hose fittings and threaded hole for bracket mounting.
For use on an early Vette with the Alt mounted on the LEFT side, the 67-68 version would be more practical, but those are VERY hard to come by. I've been looking for one (at an acceptable price) for years and finally ran across the one below for $225 (a steal today).
This is the rear. As can be seen, there is a slight variation in the threaded bosses for coil mounting.
This is a side view showing just how tall these manifolds really are.
The intakes above are PRODUCTION manifolds. The one in Scott's reply above is the GM service replacement manifold.
Look closely at the lower end of the intake runners. The service manifold has a slight flange. The production manifolds had a "plain" end at the end of the intake runners. A dead giveaway as to whether it's a production or service replacement manifold.
By the way, here's what I was referring to above regarding Chevy swapping sides with the alt and AC comp in 69 (except on Vettes and trucks).
The first two pictures are my son's 68 Chevelle, the last two are of our 70 Chevelle conv.
In my book, that was one of the DUMBEST things Chevrolet ever did!!!! Olds stayed smart and kept the AC comp on the passenger side. If you have EVER pulled an engine from a 69-later Chevy with the AC comp on the driver side, you will completely understand what I'm talking about. In order to pull the engine on a 69-later Chevy, IT IS NECESSARY TO BREAK THE AC system. Not so on a 68-earlier Chevy!
Tom Parsons
Tom Parsons
Cruise-In III Veteran
I'll 2nd the fact that the service replacement LT1 intake is almost an inch taller. Here's a pic of mine...notice the clip for the vacuum line is about an inch below where the line should hook to.
Jim
In God We Trust!
Jim
In God We Trust!
Thanks for the replies. It looks like it is a real close fit (within an 1/8 of an inch).
Joe, thanks for the info on height.
Scott, it looks like you were in the process of a frame off when the picture was taken. Did you have to shim the body up or did the hood fit? What carb and choke did you use? Did you notice a power increase?
Tom, thanks for your through explantation.
If I could find a air filter with about 2 7/8" height, it would just about solve the problem.
It also looks like I will have an issue with the choke. The intake is 5/8 taller so the rod from the choke heat raiser will have to be longer.
I measured the height on mine with tin foil some time ago. I have since installed a 5 speed so I plan a more precise measurement. I'll probably make the change when it gets colder as I am using the car in this nice fall weather. Thanks
Mark
Mark
I think the key item is having the right drop on your air cleaner base. With a 2" drop, these manifolds fit fine with a 14 x 3" element.
Mark
Mark
Here's a picture of a 14044836, reproduction, replacement, whatever, with the flange:
Larry and 66Jack
The air cleaner I have is the stock 66 a/c for an L79 and I believe the drop is 2 inches. I will keep the intake and carb as the car has the original engine.
Mark
Mark
66Jack contact Gees Corvettes in PA: Keeneyville, PA 16935
Phone: 570-376-3421
he is very easy to deal with and at Carlisle he had a few for sale
Phone: 570-376-3421
