spare tire tub bolts
I want to use a 7" rally wheel with a 215-70x15 tire in the tub but the stock bolts are not long enough to let the tub lid close, I see CC offer a 10-1/4 front bolt, and a longer locking bolt, what size bolts should I use? The wheels were on the car before I changed over to the 7" TT2's and they are the same OD so it would make a good spare, don't really want to use a space saver ....Thanks ...
Received 6,943 Likes
2015 C2 of Year Finalist
have you tried the bolts used in C3. the tub is very close I would think you could use them
i'll get some threaded rod and see what length I need then look for bolts...always gotta have a project, CC wants $50. for 2- 10-1/4 bolts ...
http://www.parts123.com/parts123/yb....Z5Z5Z50000050B
St. Jude Donor '13-'14-'15-'16
I had him send me his tub bolts and tell me how much longer they needed to be. Cut the bolt in half, welded in the extension, ground to look pretty, tempered, painted black and sent them back to him. He lives in Conn. and I'm in Sillinois. IIRC I charged him the postage.
To do the job really right, the locking bolt at the rear should also be lengthened so the tub/tire has the same space front and rear.
DonO
Good friend had the same issue.
DonO
DonO
If you'd like me to do the extending, I'd have to charge you return postage and a large cup of black coffee.
