66 windshield wiper motor number
Could anyone tell me where the winshield wiper motor number is located and also is it visible on the car or do I have to remove it to see the numbers. Thanks in advance KC66
Received 1,857 Likes
The only visible "number" on the wiper motor is usually a "13" or "14" cast into the housing just above the joint between the cylindrical stamped motor case and the aluminum housing; as far as I know, there are no other identifying "numbers" on the motor.
Not trying to come across as a know it all
But here`s what NCRS says-
53-55- 3706280
`56 5047799
`57- 5047984
`58- `62 5044266
`63- `64- 5044518
`65-67- 5044602
53-55- 3706280
`56 5047799
`57- 5047984
`58- `62 5044266
`63- `64- 5044518
`65-67- 5044602
JohnZ What is the difference in the 13 or 14? Does it mean something?
JohnNC Yes I saw that, so I was trying to confirm if my car has the 5044602 number, but I couldnt see it on the motor thats on the car. Wondering if I have to remove it to verify numbers.
KC66
KC66
The "13" or "14" is just a die-cast mold cavity number. I don't think the mylar label with the motor part number and date appeared on the steel part of the motor case until 1968 or later.
