Water spots
C2 of Year Finalist (appearance mods) 2019
CLR should work, they are probably hard water spots (calcium).
Another way to go is with "Mister Clean Magic eraser". My wife recently found out that it works great for cleaning our shower door glass. She said it comes off like magic. Give it a shot.
St. Jude Donor '10-'11
If none of the above work, 'cerium oxide' is what is used to buff out very minor scratches in windshields, so it should work for getting out water spots.
Water spots
Bob Ami powder used to have a GM part number if I remember correctly.It should be available in any good supermarket. I have used it to clean up windshields for 40 years. It takes the film and spots off without doing any damage to the glass. Bill Gould
I have used the Bob Ami in the past for hard to remove spots on glass, but I marked on the container: "Safe for glass, but use care" If I remember correctly (been a long time ago), I saw very fine scratches after using it. It is supposed to be safe for all surfaces (fiberglass tubs included), so I may just of not been careful enough to keep the surface wet enough, or I did not clean it properly before using the Bon Ami.
Plasticman
Finalist 2022 C1 of the Year - Unmodified
2020 C1 of the Year Finalist - Unmodified
C1 of Year Finalist (stock) 2019
I had the same problem. Windex, 409, vinegar, all failed - but Mcguiars Quick Glass Cleaners took care of my stubborn water spots
