Wirering a temp C2 washer pump
Hi,
I need to temporarily wire in a modern two wire Trico pump into a '67 to pass inspection.
Looking at the pic below, I gather I would run the brown wire to the positive Trico wire, but would I run the negative Trico wire to the blue wire, or ground it or both? The Trico pump is in a plastic housing.
Thanks,
Paul
Thanks,
Paul
Got it working great with the help of a friend.
Brown wire to positive on the Trico, and blue wire to the negative, works with the factory switch.
Paul
Paul
Received 1,859 Likes
